12-17-2021, 09:21 AM | #1 |
Drives: 2022 Camaro Lt1 Join Date: Nov 2021
I want to upgrade exhaust. I need advice please.
I recently purchased a 2022 Camaro LT1 Coupe. It has an RS package and dual tip exhaust. I would like to upgrade to the dual exhaust (quad tips). I really love the look of 4 tail pipes. Plus I love the sound.
I called my dealership and told them I’d like to order a dual exhaust. They told me I’d have to order the dual exhaust aftermarket, but their service department can install everything. Now, I’m a bit naive when it comes to cars and mechanics. I don’t know what type of exhaust system is currently in my Camaro; I don’t know if it’s a single pipe which branches out in a Y shape leading to the dual tips, or if there are two pipes. Anyway, does anyone know what I need to order to get those quad tips? What type of exhaust do I need to order? Also, where do you recommend I order the exhaust? - If you need more information or detail on my vehicle I’ll try and get it. |
12-17-2021, 06:21 PM | #2 |
Drives: 2016 Camaro 2SS Join Date: Mar 2018
Too bad you are so far away. I have a quad tip NPP sitting next to my house collecting dust and would give it away just so a Camaro would get it. It would fit perfect with only the 2 input pipes needing welded up. You would need to get a lower valence cut out for the quad tip. Maybe you can find a used one near you. Best, least expensive way to upgrade sound and get quad tip. Our cars have a large "suitcase" muffler with 2 pipes coming in the back and 2 pipes coming out the sides to the rear (for non quad tip, quad tip has 2 pipes coming out each side)
Mr Russ
Tim "the tool man" Taylor is my hero My Garage: '16 Chevrolet Camaro 2SS, Summit White, Adrenaline Red -- Rotofab CAI, Soler TB, 1 7/8 coated LT's, Full 3" mids, 3" Stainless Works NPP mufflers, Flex Fuel, E85/91 tuned '20 Honda Oddysey Elite 25th Anniversary Edition --wifes car, she said "No more SUV's" after the 2 CX-9's totaled |
12-17-2021, 07:11 PM | #3 |
You can just order a quad tip catback (I did the AWE Touring catback and can recommend it without reservation). Then pickup a valance off a quad tip car or buy an aftermarket one. But my car was dual tip and I agreed the quad looks much better, and it was an easy upgrade.
12-18-2021, 02:59 PM | #4 |
Thanks for the responses Joshinator99 & MrRuss. Joshinator99, that looks awesome. Thanks for the info.
12-18-2021, 05:09 PM | #5 |
12-19-2021, 08:41 AM | #6 |
Joshinator99 - one more question for you
Joshinator99, Did you need to order the entire exhaust system or or just the muffler and outlet piece? See the two attached images for what I mean.
Also, the AWS web site only has the SS and ZL1 model in the "does this fit" section. Hopefully these are compatible with LT1. I assume they are since I have a 6.2 liter, v8 w 455. Thanks |
12-19-2021, 09:21 AM | #7 |
I ordered the full catback with resonators because I knew I was removing the secondary cats. I knew I was going to go for big power down the road so I wanted to remove the crushed section of exhaust piping as well. If you’re staying bolt-ons, you don’t have to worry about that. I suspect you could order just the axleback in your situation.
12-19-2021, 09:34 AM | #8 |
Drives: 2021 Camaro 2ss Join Date: Dec 2021
If it’s the RS it’s not the 6.2 right?
Are you sure you’ll like the sound? Different engines evoke a different exhaust note. Personally I’m not a fan of 4 & 6 cyl engines with exhaust mods but I haven’t heard a ton in real life. I apologize if I am stating something that you’re aware of. Just wanted to throw in that pic if it’s not the 8cyl the sound will be different I would assume. I’ve done exhaust mods on every 8 cylinder I’ve owned so that’s where I’m limited. |
12-19-2021, 04:37 PM | #9 |
t's definitely 6.2 liters, LT1 engine V8 with 455 horses. I attached some pics and specs. The LT1 is the lowest model to start with this engine. -The RS is just an appearance package that was added to this car.
12-19-2021, 05:54 PM | #10 |
Drives: 2021 Camaro ZL1 Join Date: Jan 2016
OP, don't forget, as noted in the first response, that you'll also need to swap out your lower valence for one with the larger cutouts for 2 pipes on each side. Not a huge deal, but it'll probably cost you a couple hundred dollars to buy one, and the swap involves quite a few panel clips.
Sent from my SM-G991U using Tapatalk
ZL1 Coupe, Wild Cherry Tintcoat, Black Metallic Center Stripe, A10, Red Knee Pads, Red Seatbelts, Nav. Ordered 12/12/2020, Built 1/14/2021, Arrived at Dealership 2/23/2021, Took Delivery 2/27/2021.
