03-21-2021, 11:46 PM | #1 |
Drives: Chevrolet Camaro Join Date: Nov 2019
WTB/ISO ZL1/ZLE Front pads
As title says, Im looking to buy ZL1/ZLE front brake pads (driver and pssnger)
it has to have lots of life left in them. Last edited by jkmskfk; 03-30-2021 at 10:09 PM. |
03-22-2021, 04:04 AM | #2 |
Check the Corvette forum there was a guy with complete setup.
https://www.corvetteforum.com/forums...iron-mint.html https://www.corvetteforum.com/forums...et-dfw-tx.html
Orange Krush II
03-22-2021, 08:03 AM | #3 | |
Thank you for looking out for me but not quiet 100% sure if it is direct bolt ons, i tried to research myself but couldnt get for sure answers. Some said 14 cts V and corvette GS and Z set up would work but some also said possibly involve spacers...
03-22-2021, 09:57 AM | #4 |
Calipers an pads are the same I’m running them on my 5th Gen front wise, I think the rotor hats are different lug stud wise.
Orange Krush II
03-22-2021, 10:57 AM | #5 |
03-23-2021, 03:29 AM | #6 |
I’m running C7 corvette Z06/GS calipers on the front of my Gen5 an I’ve used CTSV and C7 pads and yes you are correct rears are different but they are the same caliper between C7 and Gen6.
Orange Krush II
03-23-2021, 07:48 AM | #7 | |
Thank you for the help |
03-24-2021, 09:26 PM | #8 |
Mounts should be the same since the share the caliper go check out Racing brake they show all the calipers an what they fit.
Orange Krush II
03-30-2021, 10:09 PM | #9 |
03-31-2021, 04:57 AM | #10 |
So front Calipers 6 piston are the same from CTSV, Gen5 ZL1, Gen6 6 piston application, and C7 GS an Z06. Now the rear calipers are different 9-13 or something like that CTSV and all V8 Camaro’s are the same an pads as well. Now the Gen6 and C7 GS Z06 are the same caliper but some say the pads are different as far as the radius is concerned. Now the PN won’t line up because of color and script on the face.
Orange Krush II
03-31-2021, 10:23 AM | #11 |
Are yours carbon ceramics?
Orange Krush II
03-31-2021, 04:30 PM | #12 |
