11-21-2012, 06:21 AM | #1 |
Drives: 2010 Camaro 2SS/RS Join Date: Jun 2011
CTS-V Red Calipers
I just found out that the 2013 CTS-V calipers also come in red.
The question is, how hard is it to get a hands on one? Also, would the ZL-1 kit from GM minus the calipers be a direct fit with the CTS-V calipers on a 2010 SS? |
11-21-2012, 06:35 AM | #2 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
Yes, the CTSV calipers are a direct fit on the Camaro with rotors, they are much cheaper too for the same ones that the ZL1 uses. I have a shop getting CTSV calipers and powdercoating them for conversions.
2017 Grand Sport, Borla X Pipe.....Enough Said
11-21-2012, 06:40 AM | #3 |
Drives: 45th anniversary edition v6 3.6L Join Date: Sep 2012
Sycraft those fit 2012 v6?
11-21-2012, 06:46 AM | #4 |
COTW 5/06/2013
yes they will , with 20" rims
Camaro ZL1 Brembo Front Brake Kit NEW 22959672 Upgrade the front brakes on your 2010-and-later Camaro SS or V-6 model NOTE: Requires 20" wheels for caliper clearancewith the larger brakes from the supercharged Camaro ZL1 – including racing-style two-piece, 14.6-inch front rotors and six-piston Brembo aluminum calipers, in red with the ZL1 logo. That compares with the 12.6-inch rotors/single-piston calipers on V-6 models and 14-inch rotors/ four-piston calipers on SS models. The ZL1 two-piece rotors offer greater resistance to warping and potentially longer rotor life, as well as reduced weight. The design features a separate cast iron rotor brake ring mounted to an aluminum “hat” that attaches the brake assembly to the wheel hub. The hat and brake ring cool at different rates, which helps the rotor dissipate heat more effectively. This racing-style disc design enhances braking performance under track operating conditions. Kit includes two rotors, two calipers and mounting hardware.
11-21-2012, 06:47 AM | #5 |
Yeap that's what I go. And your sort of local. Pm me please. Was gonna paint my calipers but I like this a lot better. Maybe give me price. Thanks
11-21-2012, 06:59 AM | #6 |
COTW 5/06/2013
22960684 Front Installation Sheet 1 20795300 ZL1 Front LH Rotor 1 20944529 ZL1 SPO Front LH Caliper 1 20944530 ZL1 SPO Front RH Caliper 1 25940448 SPO Front Caliper Pin Kit 1 25940447 SPO Front Service Pad Kit 2 20944523 ZL1 Front LH Hose 1 20944532 ZL1 Front LH Shield 1 20795302 ZL1 Front RH Rotor 1 20944522 ZL1 Front RH Hose 1 20944531 ZL1 Front RH Shield 1 11570788 Caliper to Knuckle Bolts 4 11569590 Front & Rear Hose Bolts 2 21012386 Front & Rear Hose Washers 4 22942442 Chevrolet Perf. Badge 1
