TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 07-12-2015, 07:57 AM   #1
BOONE1977
BOONE1977
Drives: 2010 camaro ss
2010 A/C WON'T COME ON
Hello, I am new to Camaro 5 so please forgive me if I do some thing wrong I have a,
2010 Camaro SS 6.2L
3 days ago my a/c all of a sudden quit cooling.
blower fan inside working good, but blowing hot air
compressor wont engage, inside the car everything looks as if it was engaging
checked fuse and relay, then hooked gauges to it, both sides equaled out to about 110
I hooked my snap on solus scanner to see if the hvac had any codes, no codes, checked all switches and compressor relay on/off everything seems to be working.
changed pressure switch, but still no power to my compressor.
after all this, I said well maybe the Freon is low, so I tried to add some but it wont take any.
my electric fans are working and I am out of ideas,
asking for help
thanks
BOONE1977 is offline   Reply With Quote
Old 07-20-2015, 10:04 PM   #2
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
You aren't going to get much help in a section that has been pretty much dead dead for 5 years.
Moving to Camaro Issues/Problems subform
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 07-20-2015, 10:33 PM   #3
wally mayfield
wally mayfield's Avatar
Drives: 2013 2SS 6M
jump the low pressure switch and see if the compressor starts..
if it does, you have a freon leak...
Strut tower brace(GM), CAI, Blade Spoiler, ZL1 wheels and tires, Heritage grill, Dual mode exhaust, and thats it, no more..except for the lowering springs..Ok Hotchkis springs were delivered today, thats it..
wally mayfield is offline   Reply With Quote
Old 07-23-2015, 10:31 AM   #4
TooCool5
TooCool5's Avatar
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP
Yes usually low freon stops the compressor from starting, try this.
2010 Camaro Auto, Inferno Orange, Titanium Interior, Gearhead Wheels AIRAID CAI
TooCool5 is offline   Reply With Quote
Old 09-21-2015, 12:13 PM   #5
R1ant04
R1ant04's Avatar
Drives: 2SS LS3
Hey Boone, did ya ever figure out wat was wrong with ur A/C? The same issue has started on mine this wknd.
R1ant04 is offline   Reply With Quote
Old 06-04-2018, 05:19 PM   #6
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
old thread lol but does anyone know the pins to bypass relay 216 or location of the hvac low pressure switch both fuses look ok ,just prior to the long drive to a hvac shop worth a try clutch is not kicking in
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
Bretts is offline   Reply With Quote
Old 06-04-2018, 10:45 PM   #7
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
well it cycles on and off after a quick wash under the hood so probably either low on refrig or a loose pressure switch somewhere
