10-18-2019, 05:41 PM | #15 | |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Lol good. I literally just came from an LS1. Still trying to familiarize myself with new stuff. I'm old apparently. |
01-16-2020, 03:18 PM | #16 |
Error code is gone (because the shop disabled it)
But the symptoms of a high idle remain. Note: The idle only climbs (to 2500) when the clutch pedal is depressed.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq Last edited by Osbornsm; 01-16-2020 at 03:30 PM. |
01-17-2020, 01:53 PM | #17 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I bet the torque tables are off because of airflow issues. The 6th gen computers are all torque based, so when idle airflow and driving airflow are off it messes with the torque tables.
In the end it is a tune issue and needs to be fixed by the tuner.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
01-19-2020, 06:51 AM | #18 |
double check for a vacuum leak...something isn't right IMHO. Spritz a little brake/carb clean (use red extension tube) at each intake port, vacuum port at the rear, brake booster, throttle body while the engine is running. If the idle rises, you found it. Nothing is going to catch fire either...use small bursts. Brake/carb clean evaporates almost immediately. If everything checks out, get the tune revised.
02-27-2020, 11:05 AM | #19 |
Source: Vacuum leak
The MSD Intake manifold has a vacuum leak. Not sure if it's cracked or just a bad gasket, but there's the culprit.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
