08-02-2019, 08:43 AM | #1 |
SNSTRSS
Stock spark plug torque spec?
I'm planning on replacing my stock plugs with new stock plugs. I can't seem to find proper torque values. I only seem to find a range. 17-22 ft/lbs. Does anyone know the exact torque spec? Thanks
2016 Black Camaro 2SS A8 NP
08-02-2019, 09:31 AM | #2 |
Drives: 2018 Camaro 2SS Redline Join Date: Mar 2019
Anti seize the threads, hand tight and 1/4 turn. It's not much.
08-02-2019, 09:38 AM | #3 |
SNSTRSS
I have read not to use antiseize.
08-02-2019, 10:59 AM | #4 |
08-02-2019, 11:14 AM | #5 |
SNSTRSS
Thanks Mick0311
08-02-2019, 01:02 PM | #6 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
I did a few yesterday...tapered seat so certainly not a quarter turn (with gasket).
Getting the boots off is the pain.
08-02-2019, 06:48 PM | #7 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Pretty sure the owners manual stated 10 lb/ft on the 5th Gen. I had those out and back a few times without issue- with anti-seize.
Haven't touch this one yet though... and I just looked and see what you mean about the boots! Glad they're protecting the wires but jeez, I'm gonna allow plenty of cooling time before I do touch'em! |
08-02-2019, 07:28 PM | #8 |
Make sure it’s the dielectric anti seize
08-08-2019, 02:28 AM | #9 |
the spec is 11ftlbs (132inlbs) on the LS and LT motors. New ac delco plugs do not require anti seize as they have a coating on them already. if reinstalling old plugs you should use a lite coat of anti seize.
08-08-2019, 05:02 PM | #10 |
SNSTRSS
Thanks
