09-26-2018, 08:50 AM | #15 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
If it is a tick associated with a leak you should be able to pin point the location and the leak my be enough to set of a CEL. If the tick occurs immediately when the vehicle is turned off it is the metal cooling down. Otherwise, unless it is a bad lifter, which you should be able to somewhat isolate, it is likely just the much thinner metal of an exhaust header as opposed to an exhaust manifold reflecting normal injection or valve train noise. Common and not a reason to avoid LTs IMO.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
09-26-2018, 09:39 AM | #16 | |
Drives: ZL1/335i Join Date: Apr 2014
It’s hard to say if what you’re hearing is worse due to something with the design of the OBX headers. I hear some very subtle metallic noise from underneath that is very rapid in frequency. Maybe that’s why it doesn’t bother me. It’s not like a lifter tick that’s less frequent and more noticeable. My headers just sound like normal combustion/mechanical noise that’s been turned up a notch or two. And sorry, I’m not sure about the wrap thing. I’ve never done that. |
09-26-2018, 10:22 AM | #17 |
Drives: 2018 Red ZL1 Join Date: Mar 2018
Mine ticks just a bit too. Have -cats and 2" Kooks. NO where near the valvetrain noise from my same-modded LS1, so not really bothering me...
Certainly wouldn't/shouldn't even be close to a show-stopper from doing the mods... Things to consider: 1. bye-bye warranty 2. Loud as F 3. Even harder not to drive like idiot and get car impounded . . . 58. Global warming 59. Oprah running for president 60. Header ticking noise My 2c |
09-26-2018, 10:33 AM | #18 |
Thank you Al Oppenheiser!
99% of the time a tick in an exhaust manifold is a leak.
Did you do a hose test? (hold a vacuum cleaner or whatever hose to your ear and probe around with the other end). You can also try a screwdriver test with a longer stick or rod (hold one end to your ear and the other end on the header) to see which tube is vibrating.
If you've already done the hose/screwdriver tests to verify it's not localized to any one area like the HP fuel pump inlet line or one of the header connections (i.e. a leak), and assuming that it really is indeed a resonance in the header tube metal, then yes wrapping it should help dampen any resonance. |
09-26-2018, 10:52 AM | #19 |
Drives: 2013 ZL1 Join Date: Dec 2012
This exactly.
'13 ZL1
'06 TBSS '98 TJ '87 GN |
09-26-2018, 11:17 AM | #20 | |
Drives: 2018 Camaro ZL1 Join Date: Feb 2018
09-26-2018, 01:06 PM | #21 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
I wonder if ceramic coating the headers would help?
09-28-2018, 07:18 PM | #22 |
So, I pulled the headers and one of them was leaking at the collector. I DID have a leak after all. Looks like I'll be swapping out to another set of headers soon. What gaskets should I use? I used oem ones but don't know if there are better ones.
09-29-2018, 07:09 AM | #23 |
OEM gaskets are fine. I would consider coating your headers. More expensive, but better looking and you avoid damaging the headers. Wrap can hold dirt and moisture, which over time can degrade the headers. Not a certainty, but it does happen.
