08-07-2018, 06:44 PM | #1 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2018
ZL1 timing advance, what's yours?
Just want to compare to see if I'm at least close to norm.
My car has: 9.10 balancer LT catless headers Roto-Fab intake 1 step colder plugs I've been doing the tune myself and just want to see how it compares. Today for example, I did a 20mph to 120mph run. Car starts off with 16*ish of timing throughout the rpm range till around 80mph and will slowly go down to 11* by 120mph, as the IAT's climb up. Ambient temp was 100*F and car was at 195*F coolant temp. 0 KR through the run. A/F ratio was 11.6:1 (have yet to set up the lambda value to display actual lamba). Any leaner though, I tend to get knock retard. What do you guys see during a decent run at high ambient temps? |
08-07-2018, 07:40 PM | #2 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
08-07-2018, 09:24 PM | #3 |
I plan on getting a cooler t-stat. I get no knock retard as it currently sits. Timing advance does go down though the longer the pull. I guess that's what you get with a tiny 1.7L heat pump.
