08-13-2018, 07:34 PM | #15 |
Drives: 2018 Hot Wheels 2SS Convertible Join Date: Jun 2011
Thanks Folks ... I'm taking it to the dealer tomorrow to see if they can replace it, and hopefully check to see if a critter is still in residence.
I've emailed the ceramic coating shop (where it's been for the last 1.5 weeks) to see what they have to say about the rodent damage, it really couldn't have happened anywhere else. I've never had it happen to a car in my driveway before, so I suspect that's not where it happened.
2018 Hot Wheels SE, Convertible, V8, 2SS, A8, MRC, Nav, NPP (WDXNTP)
1100 - 28/05/18 | 2000 - 31/05/18 | 3100 - 05/06/18 | 3400 - 15/06/18 .TPW - 16/07/18 | 3800 - 16/07/18 | 4300 - 17/07/18 | 4200 - 24/07/18 5000 - 25/07/18 | 6000 - 31/07/18 | XPEL - 01/08/18 | HOME - 13/08/18 |
08-13-2018, 07:49 PM | #16 |
Drives: 2016 Camaro 2SS Join Date: Nov 2017
I had the same thing happen only near the front of hood area. I never saw any evidence of rodents either, took it to the dealer and they replaced it for me under warranty. Hopefully your dealer is as good as the one I frequent..
Good luck Lee |
08-13-2018, 08:55 PM | #17 |
Because Racecar!
100% critter. See it all the time.
08-14-2018, 11:00 AM | #18 |
as I recall my 94 Camaro was chewed up by rats. Had a CEL illum on day and found some gnawed on wiring. Rat poison laid out in several areas took care of the problem.
08-14-2018, 12:03 PM | #19 | |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
I think the mice use the strut brace bar to access the underside of your hood. Velcro a mouse trap with peanut butter to the bar. I had to do this to my MKX which sat outside but put the trap on the engine cover. |
08-14-2018, 12:08 PM | #20 |
Drives: 2000 GMPPSV SS & 2017 ILE SS Join Date: Jul 2017
Get a cat.
j/k DOGS RULE! |
08-14-2018, 10:44 PM | #21 |
I have both
I cleaned out the garage and have my car in there now. I use one of the sonic mice "traps" out there and haven't seen mice in years. We store girl guide cookies out there, and they never get nibbled on. Will replace the cloth and consider it a lesson learned.
08-14-2018, 11:37 PM | #22 |
Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS Join Date: Nov 2016
There is NOTHING to prevent access into the car through the cabin filter slot. It is OPEN. A super easy access point for rodents..an absolutely stupid design.
After I had a mouse get into my 2017 ...then of course DIE back behind the blower motor....I fashioned some 1/8" screening over that stupid cabin air filter inlet. Problem solved. I agree...that looks a lot like what a mouse would do. |
08-14-2018, 11:55 PM | #23 |
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
Lined my garage with electronic repellents and mothballs for a reason.
08-15-2018, 04:19 AM | #24 | |
Drives: 2SS Hyper Blue Join Date: Jun 2018
I have never had the problem but our Aprilia bike guys have posted pics of mice/rodents getting into the air intakes and making a mess and chewing wiring. Toyota apparently also has an issue with some cars because of soy based sheathing on wiring () I had no idea about the cabin air filter access someone else mentioned. Will check it out.
2018 Hyper Blue 2SS - SOLD
08-15-2018, 05:42 AM | #25 | |
Drives: '17- 1ag37 V6 traded, for 1SS 2018! Join Date: Mar 2018
Got a pic? All i see, is a plastic grid with 1" square holes, covered by a rubber flap. No challenge for a mouse with any IQ at all. |
08-15-2018, 06:15 AM | #26 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
Before you park your car back in your garage, set up some traps, and it wouldn't be out of the realm of sanity to fumigate your garage. Make sure the little varmints are dead. Then check things like the weather stripping on the bottom of your garage door, around the garage door, and if you have any other doors leading to the outside off your garage. Make sure the doors are tightly sealed, have no play, and have good weather stripping all around them.
Those little sob's can crawl through something the size of a pin hole because they have no vertebrae. |
08-15-2018, 11:04 AM | #27 |
Drives: 2018 Camaro 2SS (EU) Join Date: Jul 2018
Seems to me your car has a critter infestation
2018 EU 2SS - 6MT - Black GBA - Recaro seats - NPP - MRC
Black Bowties - GM Fuel Door - Black Camaro Fender Logo - K&N Air Filter - Katech ported TB - GM Dark Tail Lights - GM ZL1 1LE 3rd Brake Light - HRE FF04 - Eibach Springs |
08-16-2018, 01:30 PM | #28 | |
Drives: 2016 Camaro SS Join Date: Nov 2015
- Jason @ Flowmaster |
