07-20-2023, 12:33 AM | #1 |
Drives: 2023 Riverside Blue 2SS Join Date: Sep 2022
What would I need to do to comfortably be over 700hp on an LT1?
I want to boost the car but I’ve heard the engine can’t handle anything over 650WHP without upgrading internals. Exactly what would I need to replace to handle ~ 700whp? And would the 10L80 need to be upgraded or replaced too?
07-20-2023, 12:49 AM | #2 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Honestly, I would just buy a ZL1 and a pulley.. ..much less headache, much less involved, and probably less expensive. After you look back at the receipts and realize you could have bought a ZL1, you will be kicking yourself.
07-20-2023, 01:56 AM | #3 |
Drives: Grandad's C2 L89 Join Date: May 2017
Absolutely, with upgraded internals and FI already in place... and a warranty.
2018 ZL1 1LE sw/PDR
07-20-2023, 07:04 AM | #4 |
I'm not kicking myself at all, even though I did spend ZL1 money on my SS. Then again, it has 200 crank hp more than a stock ZL1 (pulling like a freight train), and looks exactly the way I want, inside and outside (I still glance back at it every time I park somewhere, even after 5+ years).
There is no one size fits all solution.
07-20-2023, 07:09 AM | #5 | |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
If not, then keep the boost low 8-9PSI on the stock SBE, add a flex fuel kit, run E85, find a good tuner if you want it to live any life.... (but that is not guaranteed either) Build it and mod it your way and make it your own
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
07-20-2023, 07:11 AM | #6 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Tires, definitely tires
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
07-20-2023, 08:51 AM | #7 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
The OP questions was what would he need to do to be comfortably over 700hp on an LT1? Forge the engine/cam/heads/fuel system and 1.7 supercharge it.
Used 2022 prices - Edmunds Suggested 2SS $43,695 $42,904 ZL1 $65,895 $65,084 You have a little over $23K to play with price difference. It will no where be near stock ZL1 - suspension wise/rear end/ etc but it will have a lot more power. $23K u can make a very fast Camaro SS over 700 RWHP easily. Go for it if you like modding, if you don’t get a used ZL1 with 650 Hp to the flywheel. No need to upgrade tranny. There’s lots of threads on builds here to achieve your goal.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 07-20-2023 at 09:07 AM. |
07-20-2023, 08:56 AM | #8 |
Drives: Chevrolet Camaro Join Date: Apr 2022
Seems the way to go now would be Laynlo's route. Port injection, E85, blower, headers will get you there on an otherwise stock engine. Not sure if he's running a JMS BAP or what's on the low side though. If I were to do it again I would've skipped the LT4 fueling and went the port injection route.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT4 HPFP, LT4 Injectors, JMS BAP - 722WHP
07-20-2023, 01:38 PM | #9 | |
07-20-2023, 01:43 PM | #10 |
You won't need to upgrade the engine or trans if you do a 2650 Maggie and TooHighPsi Port Injection. I did have my TCM unlocked but we've done very little to it, just enough to keep GMs torque limits from screwing with our tune and pulling timing on the launch.
07-20-2023, 05:39 PM | #11 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
'ing for New Engine. She still wimpers to me, but I just can't explain why not.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
07-22-2023, 05:36 AM | #12 |
Drives: 2019 ZL1 1LE Join Date: Jul 2022
The problem is you don't get the money for the mods back. Mods depreciate by 70%, while a ZL1 will hold its value, so in the long run it's cheaper to buy a ZL1 and do some minor mods than spend $25k on mods on a $40k SS. That SS is not going to sell for $65k after you're done modding, more like $45k at most. Also, of the $25k at least $4k would be spent on wheels and tires because stock SS tires cannot handle 700whp.
A lot of people say they don't care about resale value because they'll keep the car forever, but I've rarely actually seen someone keep a car forever. Buy the best platform you can get and start modding that. That's a much wiser decision. |
07-22-2023, 06:32 AM | #13 | |
Drives: 2018 Camaro SS Join Date: Jan 2021
I’m missing the part where he asked if he should buy an ZL1 instead. He asked for build info not financial info on what to buy. Y’all bought a ZL1 because that what was right for you…. Y’all assume OP didn’t think about that? OP you would need to to do forged pistons and rods. Possibly a crank. I’m not on it though I would call a shop in the know and ask them…. Like Texas Speed. Sent from my iPhone using Tapatalk |
07-22-2023, 06:57 AM | #14 | |
I don't see a sea of SS owners flooding ZL1 threads with "OMG you shouldn't have spent $20-22k extra on your car, you should've just slapped a Maggie and a tune on a 2SS for $9k and have the same powaaah". To the contrary, every time someone asks about SS build/mod info, one or more ZL1 owners come in with unwarranted financial advice and questioning how "smart" the OP was for not buying the ZL1 in the first place. Leave the man be and let's help him instead. As for the build, my info is in my sig, it's a rock stable 735 rwhp (on E60) car, a perfect Jekyll and Hyde build by Jannetty Racing.
