Old 10-31-2022, 06:15 PM   #1
Conner0388
Drives: 2016 Chevy Camaro 2SS
Header help bolt broken off and cross threaded
On my car someone previously must’ve taken the oem headers off for some reason and when I was taking them out one of the header bolts broke off almost flush with the head and one of the bolts was put in cross threaded. What do I do?
Conner0388 is offline   Reply With Quote
Old 10-31-2022, 06:46 PM   #2
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Drill that hole and use a heli-coil. You can buy heli-coil kits. Just my suggestion.
Old 10-31-2022, 07:20 PM   #3
AZIROC
Drives: '86 IROC-Z '18 ZL1
Imo, id start with a bolt extractor of you think you can get in there fine. If you or u know someone handy with a welder, u can always try to weld another bolt to that 1 and screw it out.
Old 10-31-2022, 07:40 PM   #4
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
If you don’t know what to do, you should bring it someone that does. Someone that actually has the tools, skills and relevant experience. If YOU try to fix it and screw up, it’s just going to become a larger / more expensive mess.
Old 10-31-2022, 08:47 PM   #5
L78toLT1
L78toLT1's Avatar
This^
Not sure which bolts you're working on, but access isn't good on many of them. Pulling the head isn't a bad job, especially on a normally aspirated motor. I'd yank the head off and take it to a machine shop.
Baby Blue
Old 10-31-2022, 09:06 PM   #6
Conner0388
Would I have to dissemble the head?
Old 10-31-2022, 09:10 PM   #7
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
This^
This would be my advice too. Just yank the head and fix it right IMO. Crappy situation for sure.
Old 10-31-2022, 09:25 PM   #8
AZIROC
No. Ud just have to get a new head gasket and head bolts.
Old 10-31-2022, 09:38 PM   #9
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
weld a nut to it then pull it out. Then retap the hole
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 10-31-2022, 10:51 PM   #10
JTS
JTS's Avatar
Drives: 2023 ZL1 A10
You got a cross threaded and broken sheared bolt, I've had plenty of experience in racing and all the machenical that goes with it , many years ago, these new cars tight quarters around the heads, MO , pull the head or heads. Sorry I've been there not on this new stuff old school stuff . TC
2023 ZL1 A10 Shadow Gray Metallic
JTS is offline   Reply With Quote
