03-12-2016, 06:02 PM | #1 |
Drives: 20151LE Join Date: May 2015
Z28 exhaust manifold
What's you guys opinion on the chevy exhaust manifolds you can buy from the dealer? Part number 19302762. Are these considered shorty headers ?
03-12-2016, 06:10 PM | #2 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Z/28 Exhaust Manifold Package. The Z/28 high-flow exhaust manifolds will provide increased airflow to the Camaro LS3/L99 6.2L engine. This kit enables bolt-on installation of the Z/28 dual-mode exhaust system. However, it will not work with the production LS3/L99 exhaust system. NOTE: No calibration support from GM is available.
03-12-2016, 07:59 PM | #3 |
I have accumulated a set of Z/28 headers, cats, and mid pipes with a set of ZL1 dual mode mufflers, I'm waiting on some better weather an time off to install them...
Orange Krush II
03-12-2016, 09:57 PM | #4 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
I thought those manifolds wouldn't work on a LS3/L99?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
