12-18-2020, 03:57 AM | #9353 |
UK2019
Drives: Camaro 2017 2ss/eu spec convertible Join Date: Mar 2019
If you're adding the bumper drls you'll need to remove the bumper but it's not difficult. Stupidly I didn't add my sema grille at the same time so have had to do it twice now but only takes 20 minutes or so.
12-18-2020, 08:28 AM | #9354 | |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
Nice idea. How did you connect the wire to the light terminals? |
12-18-2020, 08:43 AM | #9355 |
Drives: 23 ZL1 6speed Join Date: Aug 2020
Cleaned/conditioned all of the leather and put the trickle charger on her last night.
12-18-2020, 08:46 AM | #9356 |
UK2019
I tapped into the existing trunk light wires where the cable dives behind the side panel of the trunk (black is negative, blue/green is positive), soldered joints, all wrapped up in the correct fabric harness tape. Ran the wires to the desired location, wired up the plug and cut a hole in the trunk panel using a cardboard template i made from the hole of the existing light. Looks 100% oem and the harness/wiring I added looks like it should be there too. Very simple to do, anyone can do the same and only cost a few pounds/dollars.
12-18-2020, 09:34 PM | #9357 |
Drives: 2019 Camaro 2SS Join Date: Jun 2019
I paid off my car loan.
She's all mine, free and clear |
12-18-2020, 09:48 PM | #9358 |
Ghost Spawn
Drives: Camaro Join Date: Jan 2019
12-19-2020, 02:44 AM | #9359 |
Drives: 2020 1SS 1le Join Date: Apr 2019
I hit 153mph in it for the first time
12-19-2020, 04:02 AM | #9360 | |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
12-19-2020, 06:49 AM | #9361 | |
UK2019
If you're adding the bumper leds, grey/blue is positive and black is negative. If you wire it up this way they will go off whilst indicating during the day on that side which is what I chose since their brightness and distance between them and the indicator means for MOT purposes it's probably the safest. You can wire them up to be always on (as is oem in the US) by just wiring them to ignition 12v either to the fuse box or the front bumper harness but not sure how an officious MOT tester would feel about it. I also put a waterproof in-line switch to the bumper leds in case ever challenged at MOT time. Easy to just switch them off and say they're for off road use only rather than having them wired into ignition 12v or without a switch and having the hassle of disconnecting them. Sorry I didn't think to take pictures at the time but it's very simple and if you route wires properly and wrap them in cloth harness tape, it looks just like oem. |
12-19-2020, 06:55 AM | #9362 |
Makis
Thank you Uk2019. I really appreciate the detailed info on the DRL/side markers wiring.
12-19-2020, 08:02 AM | #9363 |
Drives: 2019 Camaro 2SS manual Join Date: Feb 2020
12-19-2020, 06:59 PM | #9364 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
Threw my rod and reel in the car and went offshore for grouper today.
12-19-2020, 11:08 PM | #9365 | |
Drives: Chevy Camaro Join Date: Dec 2019
How did you go about finding a plug for the extra light? |
12-19-2020, 11:55 PM | #9366 |
2020 Shadow Gray 2SS
Sat at home today on a beautiful day with the car cover on, put it on a few days ago because I was going to be gone for work until late on 12/23 so covered it up, ended up home today unexpectedly but decided not to take the cover off for a single day and then have to recover it... I'll drive it Christmas eve... Almost had my 2020 2SS a year (just rolled 3,000 miles) and still love taking it out and letting the NPP sing...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
