Old 08-11-2017, 07:46 AM   #71
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Originally Posted by devnull View Post
You're right, mine did take a little more on second top off, even after the sit (but maybe an ounce). GREAT VIDEO! THANKS
Mishimoto needs a 1LE haha
I almost wonder if topping off the diff after it warms up and pulls some fluid in the diff itself, could possibly lead to too much fluid in there? The amount is probably small enough that it wouldn't be an issue...but just a thought.
Old 08-11-2017, 07:22 PM   #72
devnull
Scientific negotiator
devnull's Avatar
Drives: 2019 Grand Sport
Nah, I've opened it many times and the amount that seeps is the same as the factory fill... No worried there
2019 Grand Sport M7
2018 ZL1 1LE 6MT
2017 SS 1LE 6MT
Matthew 25:40
ΜΟΛΩΝ ΛΑβΕ
devnull is offline   Reply With Quote
Old 08-11-2017, 09:58 PM   #73
MySS8U
MySS8U's Avatar
Drives: Black 1SS 1LE
Noob Question
Originally Posted by TrackClub View Post
Guys...read the manual - the info is all there
Tranny/diff fluids should be changed every 20 hrs.
How many miles is 20hours for a the M6?
JALB
MySS8U is offline   Reply With Quote
Old 08-11-2017, 10:01 PM   #74
MySS8U
MySS8U's Avatar
I see 30 hours of track usage for the auto trans on page 205. Can you please point me in the right direction?
JALB
Old 08-11-2017, 10:02 PM   #75
TrackClub
TrackClub's Avatar
That's every 20 *track* hrs. So about 10 track days.
If you don't track the car - I think 70,000 miles but really unsure - sorry, pls ref the manual.
Old 08-11-2017, 10:10 PM   #76
TrackClub
TrackClub's Avatar
For the 1LE it is 20 TRACK HRS (about 10 days assuming 4x30min sessions per day) for both the diff and the tranny. Albeit I believe the tranny calls for 24hrs. But I always have them done together.
Away from the car now so no access to the manual. It is either in the main manual under Performance Driving, or in the HP Supplement - can't recall now.
This assumes you track the car regularly. If not std maint intervals apply and they are listed under Maintenance I think for each component incl the above two.
Old 08-14-2017, 08:23 AM   #77
1LEMATT
1LE enthusiast
1LEMATT's Avatar
Drives: 2017 SS 1LE
I have not seen this in the manual in regards to the trans? In the updated performance guide it only says to change the automatic trans fluid every 15 hours of track use. Which would only apply to the ZL1.
The only thing I see in regards to the SS 1LE fluid changes is in regards to engine oil, and diff fluid.
2017 SS 1LE
1LEMATT is offline   Reply With Quote
Old 10-01-2018, 07:33 AM   #78
Jcvibby
Drives: 2017 SS 1LE
What’s the go to diff fluid for track use??
Jcvibby is offline   Reply With Quote
Old 10-01-2018, 07:56 AM   #79
TrackClub
TrackClub's Avatar
I use GM fluids as specified in the manual for both ediff and tranny.
Old 11-11-2018, 10:43 AM   #80
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
cool video of diff fluid in action
https://www.facebook.com/MundoTuerca...196970889/?t=1
Old 02-21-2019, 03:09 PM   #81
Jerry7297
Jerry7297's Avatar
Drives: 2018 2SS/ 1LE
Originally Posted by carguy55 View Post
Cool video
Jerry7297 is offline   Reply With Quote
Old 02-26-2019, 09:16 AM   #82
jpdaugherty
jpdaugherty's Avatar
Drives: 2017 Camaro SS 1LE
Are most of you guys running 75w90? In the manual for the ATS-V & Corvette the E-Diff calls for Dexron VI ATF
2017 Camaro SS 1LE
IG: pdaugherty7
YouTube.com/PatrickDaugherty
jpdaugherty is offline   Reply With Quote
Old 02-26-2019, 09:56 AM   #83
TrackClub
TrackClub's Avatar
And in the SS 1le manual it calls for a different fluid (not ATF). That's what i run.
Old 02-26-2019, 03:56 PM   #84
jpdaugherty
Did a little more research, the 2019 manual for the Corvette says to use DEXRON-VI ATF in eLSD models (Z51, ZR1, Grand Sport & Z06). This is what I'm going to use. But sounds like 75w90 is working well!
https://my.chevrolet.com/content/dam...ers-manual.pdf
see page 321
2017 Camaro SS 1LE
IG: pdaugherty7
