Old 05-28-2022, 10:30 AM   #1
Crushed 1LE
Crushed 1LE's Avatar
Drives: 2022 ZL1(FEA suspension) Rapid Blue
Track alignment
Just finished converting my ZL1 to the FEA suspension components (kept the MRC). I also have Vorschlag camber plates up front.
For the track rats.... What have you guys found to be the best configuration? Iike I said, I have camber plates SPL toe and camber arms in rear, so plenty of available adjustment.
My previous ZLE, set in track mode destroyed the front left tire after 2 days. That being said, I'm also after the best turn in and balanced setup. My local track has 23 corners, most of them off camber and very technical with a complex entry from the previous corner.
Love to hear the experienced and see what setup you guys are running.
Crushed 1LE is offline   Reply With Quote
Old 06-29-2022, 11:18 AM   #2
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
I know you have a ZLE but I have an SS 1LE and this is my setup. I can let you in a week how it goes but so far I can tell the difference from my old alignment and this one. I could’ve went 1.5 on the rear but I wanted to see what this degree can do.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is online now   Reply With Quote
Old 06-29-2022, 12:27 PM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i did -3.5 f -2.5 r and tire wear is super even and nice !
Old 06-29-2022, 12:31 PM   #4
Blackmonba6Gen
BLUPRINT_1LE
Do you daily your car with that setup Or is it full purpose road course car?
I don't have a trailer so I drive back & forth to tracks so I dont want to shred my tires on my way there
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 06-29-2022, 12:38 PM   #5
kropscamaro16
pretty much at the time and point only drive my car to the track and back and back into the garage she goes
Old 06-29-2022, 12:58 PM   #6
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
For the most part its toe that will wear your tires not the camber
Old 06-29-2022, 01:02 PM   #7
Blackmonba6Gen
BLUPRINT_1LE
You're right, I dont know why I keep thinking it's reverse.
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 07-08-2022, 06:19 PM   #8
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
-3.5 f and -2.5 r with close to zero toe as I could get. Tire wear has been great with SC3Rs
