10-09-2021, 06:19 PM | #1 |
Fore triple in-tank pressure settings
Fellas,
Just trying to get an idea of the best settings for the Fore low side system. Fore recommends at least 68 psi and LPE is suggesting 100 psi at WOT. So I guess my questions are: 1. Do you set the bypass regulator at exactly the same psi you're commanding on the low side? 2. If LPE wants 100 psi, I'm assuming I can just command that under High Flow fuel conditions (and not have to run that much all the time)? 3. Can I set the regulator at 70 or so psi for normal driving, and still command 100 psi from the fuel system at High Flow? 4. Or do I set the regulator at 100 psi, and let the fuel system run 70 or so around town anyway (essentially returnless at that point, right?). Thanks!!!
10-13-2021, 06:26 PM | #2 |
Gotta be someone else running the Fore in-tank setup….
10-13-2021, 10:52 PM | #3 |
Shouldn't it be setup similar to a Auxiliary system? The Fore system doesn't turn on until a preset boost level right? If so I would think you would just have it come on @ 2-4psi and ramp right to 80+ psi and make sure your max pressure desired table is set a little higher then the pressure you want to run that way it doesn't try to throttle down the main pump. Idle or part throttle I wouldn't run more then 50psi.
2016 NFG 1SS A8
10-14-2021, 07:14 AM | #4 |
Drives: 18 Z1E - 18 Raptor - 17 Jeep SRT Join Date: Dec 2019
With the Fore, setup isn't one pump setup to run 100% all the time? Meaning it is not controlled by the FPCM. The 1st pump receives the signal to turn on from the FPCM, but that's it. Then the additional pumps come on with a set amount of boost pressure from a switch. Once the regulators set at 75psi, it will not allow you to drop down to 50psi for cruising around. The only thing you could do is set up the regulator with a boost reference line, which could add pressure to the system under boost only but you wouldn't get to 100psi starting at 75psi.
10-14-2021, 07:16 AM | #5 | |
My questions really center around the return regulator. I’ve got that set around 70 +/- right now and commanding 72 psi. I’d really prefer to run ~50 around town and 80+ at WOT. If I leave the regulator where it is, can I run the system at 50 psi around town? That would essentially be returnless again, since the regulator will be closed? And if I command 80+, is it just going to bleed off anything over 70, and therefore be a waste of time? Should I just crank up the regulator to the max pressure? Good news here is the fuel goes directly to the LPE BB HPFP first, then on to the regulator, so perhaps commanding higher settings than the regulator would be ok? I was hoping someone had experience, as the return setup makes it different than a typical aux setup. The other good news is I’m having zero issues at WOT, but want to dial up the pressure to help the HPFP.
10-14-2021, 07:26 AM | #6 |
Cant run what the regulators not set to. If it's set to 75 you're going to get 75.
10-14-2021, 11:25 AM | #7 |
Drives: 2016 Camaro SS Join Date: Sep 2018
I'm running the Fore triple set up with the Crawford Racing port injection kit, I unfortunately didn't set it up so I don't have an answer. All I know is one pump controls the low side and the other two for port injection are set to come on at around 6 psi.
10-14-2021, 11:51 AM | #8 |
Which makes sense obviously, but can I run less than the regulator setpoint with the primary pump?
10-14-2021, 11:55 AM | #9 | |
10-14-2021, 12:24 PM | #10 | |
From the instructions - "If FC2/FC3 is used on a vehicle originally equipped with FPDM or FPCM, plan ahead with the calibrator since the ECU will return alarm/error codes. (FC2/FC3 will handle fuel pump load instead of FPCM/FPDM)" |
10-14-2021, 04:42 PM | #11 | |
Here are the pics from the Fore documentation and a layout of how my system is piped in, if that helps.
10-14-2021, 05:42 PM | #12 | |
If you didn't have the low side fuel pressure sensor the car would probably go nuts thinking it had no pressure and you wouldn't have any reference when logging if your lowsides keeping up. All the FC3 is looking for on the remote side is a signal over 6.5 volts making the relay either on or off. You can pull the cover off the FC3 it's just a regular relay and fuse inside for each pump circuit. If the FPCM or whatever the brains called was still controlling the primary pump the relay inside the FC3 would melt in no time, it's not made to be shutting on and off rapidly to contol fuel pressure. It's just a standard relay for each pump circuit. |
10-14-2021, 06:12 PM | #13 | |
10-21-2021, 07:06 AM | #14 |
Drives: Turbo 6.2 Join Date: Feb 2019
great read guys, thanks
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
Thread Tools | |
