Old 04-10-2021, 03:57 PM   #1
raidaru
Drives: 2SS
2016 SS running rich, gas in oil
All right, I've got a 2016 SS with 9k miles on the clock, engine runs rough and very rich, to the point gas found its way into the oil and on acceleration comes black smoke from the pipes. Scanner shows no fault on ECM. I've recored some live data on idle and also @ 2.5k rpm, if u spot sth abnormal in the data let me know, thanks
https://streamable.com/e8xupt
https://streamable.com/h80k1m
https://streamable.com/w6ugmy
https://streamable.com/q5lkmb
raidaru is offline   Reply With Quote
Old 05-30-2021, 06:55 PM   #2
Dudeman669
Dudeman669's Avatar
Drives: 2016 Camaro SS
Sticky or stuck injector.
Dudeman669 is offline   Reply With Quote
Old 05-30-2021, 08:51 PM   #3
Trochoidal
Drives: 2017 Camaro 2SS A8
Did you pull plugs to isolate cylinder?
Also looking back at your older posts, this problem existed. Did you find it last year?
https://www.camaro6.com/forums/showthread.php?t=578979
Old 05-30-2021, 09:07 PM   #4
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Gotta pull plugs and find the messy wet one!
