06-04-2021, 10:36 AM | #197 | |
06-11-2021, 10:24 AM | #198 |
Drives: 2016 2SS, Red Hot, NPP, Nav, M6 Join Date: Jul 2016
Reading through this very informative thread convinced me to order a custom marine cable detailed per the multiple responses here, and install it to the bolt on the sound enhancer bracket. Although I have never been stranded by the hot start issue, I sure have experienced the slow turnover and associated concern of "is my battery dying?".
Thanks to all for such a good thread. |
06-11-2021, 12:40 PM | #199 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Still going strong, and it’s time for summer time testing.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
06-11-2021, 03:15 PM | #200 |
Drives: 2016 Camaro 1SS Join Date: Aug 2016
Mine has now been tested many times on several hot days here in Sacramento. This 100% fixed my slow start when hot. Thank you to everyone on the forum.
06-11-2021, 09:09 PM | #201 |
Drives: Chevrolet Join Date: Apr 2021
06-11-2021, 10:58 PM | #202 |
Drives: Former Owner '16 Camaro 2LT V6 conv Join Date: May 2021
I think this is the first V6 post on the thread. I used an existing grounding location for some wiring harness that’s in the perfect location to rout to the grounding lug. This spot looks like it’s used as a tensioner mount on some other variation of this engine.
I didn’t realize how massive a 1/0 cable is, but that’s what I ordered. 21” is almost perfect. 20” or maybe 19” would have been better to avoid rubbing on the computer gizmo under the fuse box, but I got the dual jacketed cable form batterycablesusa.com, so it should last for a decade or two. According to advanced (and the dash notification), my battery is shot… I think 11.5 when off. My starter tested good (10.67V), but the fella said that from his experience its cranking voltage was on the lower end. Hopefully it’s fine. The engine cranks like a beast after doing this though. Have had a couple hot starts and is flawless. |
06-11-2021, 11:03 PM | #203 | |
06-11-2021, 11:35 PM | #204 |
06-12-2021, 12:20 AM | #205 |
You're welcome . This is where the levels should be (top surge tank chamber 100% full, bottom chamber at about 40-50%):
06-12-2021, 12:06 PM | #206 |
Interesting. I’ve seen a non-pressurized overflow tank, and a reservoir attached to the lower hose and is above the rest of the system that the coolant level stays high enough to keep the system full. But I’ve never seen whatever this is.
Edit: Additional question. I assume I use dexcool. I’ve heard of it referred to as dexkill. Are there any coolant threads on here with recommendations on what to use? Last edited by Blobby; 06-12-2021 at 01:33 PM. |
06-12-2021, 06:53 PM | #207 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
Great reads. I just did this since i replaced the starter AND battery before finding this post. Hopefully this will solve my issue. Will give feedback in a few days
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
06-12-2021, 07:10 PM | #208 |
Drives: chevy camaro 1LS Join Date: May 2021
Is there a write up somewhere on where this ground cable goes?
The real test may be in July/august... |
06-13-2021, 11:04 AM | #209 | |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
06-13-2021, 02:04 PM | #210 |
3/8 for both ends seemed to be perfect. The bolts took a 15mm wrench. I didn’t have to do any mods to get them in. Both locations I used were dedicated electrical points so no risk of anything falling apart.
