08-14-2017, 11:39 AM | #29 | |
Drives: 2016 Charger Hellcat Join Date: Jul 2017
I appreciate the feedback, folks...but let's not profile each other over suspension choices! R. |
08-14-2017, 11:39 AM | #30 |
Drives: Sold Join Date: Mar 2017
Tires/wheels first, then aero... You'd be amazed how much just a proper wheel/tire and the right (for the track) alignment will help you go faster through corners w/ grip. Unless you're regularly running a road course where you're hitting triple digits, your benefit from aero will not be as much.. Your wheels and tires, with less rotating mass (if you can swing it from the combo, is noticeable everywhere as it's the outer most moving mass) AND you'll have the more traction advantage everywhere which means you can spend less time braking and more time on the accelerator and quicker on the gas out of a turn.
08-14-2017, 11:43 AM | #31 | |
All MFGs tune and tweak their car on that track and some outright cheat with options that never even show up. Don't even play that card. If the car was going to overheat and be an issue... it would have shown up there... Also, why is it that C7 Vettes don't have a single GM published 'ring time??? None of them.. Not even the manual trans. Show me, like with C7 Autos, where Gen6 ZL1 automatics are having wide reported cooling issues and going in to limp mode? For f*ck's sake... GM took the improved cooling aspects from Camaro and applied it Corvette to make them stop/slow down with the limp mode.. That's why new Z06s get cooling ducts, taller lid, bigger bricks and a revised underhood insert. You just don't like automatics for some reason, but that doesn't mean they have issues just because you're biased w/o real data. |
08-14-2017, 11:49 AM | #32 | |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
The transmissions are a wash as far as lap time. Neither is better than driver variance between laps....even a pro like Randy. |
08-14-2017, 11:57 AM | #33 | |
08-14-2017, 12:03 PM | #34 | |
Bring It
That's all the 1LE is anyway, parts smacked in to a ZL1. Remember this is only a trim package of the ZL1, not a different car. Just want to make sure you're very aware of this. There are no other differences than those parts mentioned.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
08-14-2017, 12:04 PM | #35 | |
I know i am Not 100% like my car, and will be adding CCB to the car next year as soon as this year is done. |
08-14-2017, 12:22 PM | #36 |
Here you go some prof of said problems of ZO6 with autos.
http://blackflag.jalopnik.com/corvet...-be-1796070293 You guys think this has more to do with it then anything else, Like i said i have run in a lot of groups and every ZO6 Auto was taken off the track with a flat bed, in any temp over 80 degrees, M7 corvettes did not have this problems, now i have been out on the track with 6th gen ZL1 and they show no sign to the heat soak. |
08-14-2017, 12:33 PM | #37 | |
The overheating issue is when left in Auto mode as the trans programming keeps the engine as high in revs as it can, so it never falters, never drops, etc. like a human would.. It just beats the engine to death and the cooling system isn't capable of removing all the thermal buildup.. That's more of an issue with the radiator and intercoolers than the trans, it's just that trans gets the blame.. Why? Because it's better at shifting than a human being, so it's pushing the engine to the computer limits unlike a human.. That's why the manuals don't have that issue.. That 7 speed is geared differently and the triple overdrive in it is complained about regularly as to why it's not 5 race gears, a 1:1 and 1 OD. The "work around" is to run the transmission in manual mode because inevitably, a human isn't going to keep it in revs the same way the computer will.. Thus, less heat to dissipate, thus longer intervals before build up. Same applies to the manuals. Different gearing forcing drivers to make different choices about which gears to chose while in session. That has an effect on the amount of thermal output the engine is making at any given time and over the long haul, will simply take longer to build up.. You could say the same about some people getting brake fade and some not.. People could easily blame the brakes and not take in to account that those with fade are braking incorrectly and building up undue heat when they could simply shift the kinetic energy transfer to the traction surface by braking later and shorter and letting the tires carry additional load, but that takes more skill and trust in your setup to not drag the brakes from marker 5, instead of a quick hard blast at marker 2 and then go hotter in to your turn... But, again, brakes would be blamed as many would brake at 5 corner after corner and overheat them. What was in question was your blanket statement about the automatic car in general heat soaking which is not correct. The ZL1 transmission is even bolted right to the engine and doesn't get the benefit of being rear mounted away from the massive heat source that is the engine and the two constantly sharing heat with each other thus compounding the issue.. That it still isn't overheating is impressive as C7Z's trans is in the rear, so all that heat would need to conduct up the TQ tube to the engine.. So, the engine is screwing itself up with revs based on shift-algos and it can't shift that thermal load out fast enough... Last edited by Mr. Meh; 08-14-2017 at 12:59 PM. |
08-14-2017, 12:39 PM | #38 | |
If I add everything from a 1LE to my ZL1, it's just a modded ZL1. It will never, ever be a ZL1 1LE because the mfg did not make it as such. My issue with you is making blanket statements about automatic cars like they're all the same. |
08-14-2017, 01:11 PM | #39 |
Have it your way, ask GM all you like to put an A10 on a ZL1LE, good luck, but they have not done it, wander why? not me.
08-14-2017, 01:12 PM | #40 | |
v It bites.
Drives: 2011 IBM 2SS/RS Join Date: May 2008
No one denies the Z06 didnt have issues including the poster, but that sure as hell isnt evidence that a completely DIFFERENT transmission will replicate those Issues.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit. |
08-14-2017, 01:13 PM | #41 |
BTW, unless you have some serious driving ability (most of us are enthusiasts who are are not on the level of a Randy Probst), the A10 will be a faster car.
That is to say that MOST of us will be able to hustle the auto around a road course faster than the M6. Yes, if you are a top level driver, the disparity between the two lessens or even vanishes, but very few owners will ever see that happen. I used to think I could do anything with the manual Evo X...and then I spent time in the SST auto version and I was significantly faster, more confident...and dare I say...safer at the limits. I absolutely respect that the M6 is a more connected experience for some and I love manuals. But the A10 is faster in the real world on real roads with real drivers. There's every reason to offer the A10 on the 1LE. It's just about crazy not to....even two dealers I spoke with agreed on that. Limiting choices just sucks! R. |
08-14-2017, 01:15 PM | #42 |
v It bites.
We know exactly why... because of bias and close minded ideologies. When someone says "it's for the enthusiast" that doesn't quite jive with the heat soak theory. The project manager himself has hinted to exclusivity.. period
2011 2SS/RS
