Old 03-27-2021, 12:23 PM   #29
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
Originally Posted by cthompson07 View Post
Side skirts were fine but took two tries for some reason. I followed these instructions from American Authority. Cleaned everything and held them up to test fit and they were great. Started mounting (3m tape across the entire top section) and they had a big gap right under the back part of the door. Took them off and re applied 3m and they fit fine the second time. Both side skirts did the same thing, fit fine on test fit, had a gap first time trying to install, fit fine the second time.
There’s about 6-8 screws that screw in the bottom (they screw up into the bottom of the stock panel) and then two in each wheel well going towards the middle. The front wheels can be turned to allow access, but the rear wheels have to be removed.
https://www.americanauthority.com/pa...lation-guide-1
Thanks for the info, they look good.
2004YZFR1 is offline   Reply With Quote
