03-17-2021, 01:27 PM | #1 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Second day driving the 416 around
Looking forward to getting it tuned next week.
Wilkes Performance assemble 416 shortblock Texas Speed 243/255 custom cam Milled PRC 260 heads 12.6:1 compression https://youtu.be/OieuFZTRec8
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
03-17-2021, 01:34 PM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Nice. Is that your SCR or DCR?
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. Last edited by Black_SS10; 03-17-2021 at 04:03 PM. Reason: Spelling correction |
03-17-2021, 02:32 PM | #3 | |
Drives: 15 Camaro SS Join Date: Oct 2018
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
03-17-2021, 03:13 PM | #4 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Careful with the weather over there.
03-17-2021, 03:15 PM | #5 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
I like it.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
03-17-2021, 03:29 PM | #6 |
Pretty badass!! And stay safe with all that nasty weather..
03-17-2021, 03:53 PM | #7 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
The camera must have a Cam in it too. Lol
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
03-17-2021, 04:02 PM | #8 |
Drives: Never just fly under the radar Join Date: Jul 2015
Just nasty love it and the license plate for it!
Old Skool |
03-17-2021, 06:16 PM | #9 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
That sounds wicked!
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
03-17-2021, 06:35 PM | #10 |
03-17-2021, 07:51 PM | #11 |
SomeguyK
More to come. |
03-17-2021, 08:06 PM | #12 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Damn speaker was cutting out. If I was your neighbor, I’d call the cops on u everytime that started up.. lol
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
03-17-2021, 08:11 PM | #13 |
I love it.
03-17-2021, 11:08 PM | #14 |
Drives: 2015 2SS A6 Commemorative Edition Join Date: Nov 2019
That sounds incredible!
