Old 04-15-2019, 08:07 PM   #1
z28pat
z28pat's Avatar
Drives: 2002 z28, 2018 2ss 1LE
Ceramic coating for brake dust
I have a 1le with those dusty brake pads and I’m curious if anyone has tried the ceramic coating for this purpose? What kinda results did you get , did it work ?
Thanks
z28pat is offline   Reply With Quote
Old 04-15-2019, 09:04 PM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Yes. Before I swapped out my stock pads I put a coat of Gtechniq Crystal Serum Black + a coat of EXO on the wheels. It reduces dust buildup a little and helps make cleaning easier. A hose rinse will get most of the dust off most of the time. But coatings won’t prevent the sticky brake dust from getting on the wheels. And you’ll still need to use soap and agitation to get grease and oils off the wheels.
The best way to manage dust is to swap out the pads for Powerstop z26 or similar, but that’s not an option if you track your car.
Old 04-16-2019, 09:10 AM   #3
SSJ455
SSJ455's Avatar
Drives: "Kara Zor-El" 2017 2SS HBM
Have you had any issue with the rotors warping with the ceramic pads?
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!!
What?
Dangerzoooooone.
SSJ455 is offline   Reply With Quote
Old 04-23-2019, 01:45 AM   #4
peteric
Drives: 2016 camaro
Ceramic coating makes cleaning the wheels a lot easier.
peteric is offline   Reply With Quote
Old 04-23-2019, 08:46 AM   #5
WILWAXU
WILWAXU's Avatar
Drives: 2019 Crush ZL1 1LE
Yup, my wheels and calipers are coated. Makes for quick and easy clean up.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
WILWAXU is offline   Reply With Quote
Old 04-23-2019, 10:01 AM   #6
Soleil
Soleil's Avatar
Yes 100% agree.
Don’t expect „no dust built up“ but the cleaning is much more easier.
Soleil
Old 04-23-2019, 10:13 AM   #7
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
It’s important if you’re a novice to understand that the coating is just going to let the brake dust sit on top of the coating, rather than on top of the painted surface, therefore much easier to get off. But the volume of brake dust will go on unabaited until you mount a “non-track” pad like the powerstop.
Old 04-23-2019, 10:26 AM   #8
VinnAY
Drives: 18 1SS/1LE
Doesn't this stuff seem pretty expensive? I don't know if what I'm looking at is the right
product(s) but I get sticker shock with ceramic products.
Old 04-23-2019, 11:47 AM   #9
441bertre
441bertre's Avatar
Drives: 1998 SS, 2018 1LE
I purchased the Adam's Wheel Coating Kit for my 1LE. I've only washed the car once since I applied the coating, seemed like it helped when I cleaned the wheels. I'm not a big ceramic coating fan but I would recommend.
1998 Chevrolet Camaro SS
2018 Chevrolet Camaro SS 1LE
Last edited by 441bertre; 04-23-2019 at 11:49 AM. Reason: tHiS pOsT iS wOrThLeSs WiThOuT pIcTuReS
441bertre is offline   Reply With Quote
Old 04-23-2019, 06:41 PM   #10
Gunkk
Gunkk's Avatar
No issues whatsoever. Haven't heard of any warped rotor issues on or cars. The Brembos are stout.
Only self- inflicted issue is a mild squeak in the rears when cold because I left off the shims.
But it goes away after the first stop so it's all good.
Old 04-24-2019, 09:26 AM   #11
SSport16
SSport16's Avatar
I have been using Hydro2 on the wheels, gets in all the small spaces that you can't get into on the wheel. Then I follow up with an application of Reload. I do this at least twice a year. Still have tons of brake dust, but as mentioned above, it is easier to get off. I like to wipe my wheels down, especially the barrels, each and every time I am done driving the car for the day.
Old 04-24-2019, 10:38 AM   #12
SSJ455
SSJ455's Avatar
Thanks. I bought some Powerstop pads and rotors. I may attempt to install them this weekend. I haven't done brakes before so I am a bit apprehensive. I saw a good video on youtube from LethalCamaro so I am trying to get youtube certified.
What?
Dangerzoooooone.
Old 04-25-2019, 07:12 PM   #13
CanyonCarver
Finding New Roads
CanyonCarver's Avatar
Drives: 2016 Camaro 1SS
Changing the brakes and rotors is SUPER easy
EXCEPT for the caliper bolts. You'll need a medium breaker bar. They are tight af
I am a fan of coating tires as well. SOME dust will "stick less" and clean up is much easier
CanyonCarver is offline   Reply With Quote
Old 05-01-2019, 03:50 PM   #14
Osbornsm
Drives: 2018 SS 1LE
Yeah i noticed that too.
The two main brake caliper bolts are put on there with a THANOS level of torque.
Anybody have the ft/lb for how tight they should be?
- I've been using the German torque spec... gutentite.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
