05-22-2020, 08:42 AM | #1 |
Drives: Z28 want Join Date: Mar 2014
Which is lighter, NPP or no NPP ?
Does anyone know if you save weight either way.
With or without NPP ? Is there a weight difference ? Also is there a dyno difference between the two ? THANKS ! |
05-22-2020, 09:32 AM | #2 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
Stock NPP will weigh more.
Valves, plumbing, wiring. That being said, moding it and having an AM axle/cat back will lighten it back up and, depending on the system, you can have the valves to bypass the muffler.
05-22-2020, 09:32 AM | #3 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
I'm willing to bet the weight and power difference is so negligible that you couldn't even actually measure it
05-22-2020, 09:46 AM | #4 |
TD
Drives: 2017 2SS, 2014 Mercedes C300 Join Date: Feb 2020
No weight difference
05-22-2020, 10:44 AM | #5 |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
I think someone cut their NPP off and it weighed about 35lbs. And was about 2 lbs lighter than the 2 axle back mufflers they installed.
05-22-2020, 11:04 AM | #6 |
Isn’t taking weight off of the rear of the car going to negatively affect rear wheel traction?
05-22-2020, 11:06 AM | #7 |
05-22-2020, 11:29 AM | #8 |
Two Lane Blacktop
Drives: '18 Camaro 2SS Join Date: Jul 2019
The stock muffler will weight more then the NPP valves, there is no power difference. One rating
05-22-2020, 11:50 AM | #9 |
without but who cares lol
05-22-2020, 12:02 PM | #10 |
At one time I had a both of them in my shop I think it was seven pounds difference. NPP Muffler was a little heavier, then you have the additional tips, then the valves.
05-22-2020, 05:10 PM | #11 |
I guess the real question is what are you doing with your car that the weight of the muffler is a factor? Most people, when it comes to exhaust, are more concerned with efficient flow. You’ll gain a whole lot more power when focused on that rather than the 5-10 pounds added by a muffler. With a lighter muffler you might shed 0.000000001 second off your 1/4 mile time! If you’re really concerned about weight, go with a muffler delete. Problem solved.
05-22-2020, 05:29 PM | #12 |
Drives: HB 2SS Join Date: Apr 2017
NPP stock system isn't too heavy compared to the aftermarket. Infact it's generally only a few pounds difference. The real kicker is the aerodynamics. From what I read removing it removes the smooth airflow from below and the valence will introduce drag. Not sure how thoroughly this has been tested but it's something to think about.
If you're satisfied with the sound as it is. I would leave it. If you want more sound, try to go after the headers instead or the secondary cats to see if it's more your cup of tea. In terms of performance the stock NPP is fantastic and switching to aftermarket generally does nothing. |
05-22-2020, 05:39 PM | #13 | |
05-22-2020, 05:50 PM | #14 | |
Dumb Ass Deluxe
