Old 08-18-2017, 02:31 PM   #1
Slow_V8
Slow_V8
Slow_V8's Avatar
Drives: 16 white 2ss
Best exhaust system and headers for 16 ss?
I currently have stainless works catback exhaust system... thinking about getting a MBRP exhaust system with the 2" kooks Long tube headers with off Road pipes... I would like some review on those mods and if I should use these system instead of buying a 2" Long tube headers system from stainless works....
2016 white 2ss, stainless work exhaust system and K/N CA
Slow_V8 is offline   Reply With Quote
Old 08-18-2017, 03:43 PM   #2
Arugon
Arugon's Avatar
Drives: Summit White Camaro SS
I've got a Borla ATAK Axleback and love it.
Arugon is offline   Reply With Quote
Old 08-18-2017, 04:00 PM   #3
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
For NA and even some lower power FI cars 2" is overkill. 1 7/8" will support up to 1000 rwhp.
djfury05 is offline   Reply With Quote
Old 08-18-2017, 04:15 PM   #4
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Myself. If I were to layout some cash. I will go Hooker. Love that system.
Old 08-18-2017, 04:30 PM   #5
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Like someone said 2" is overkill unless you're going high HP.
MBRP usually sounds very good in any brand.
If you decide to let go of your SW.. HMU I might buy it.
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
G2K is offline   Reply With Quote
Old 08-18-2017, 04:36 PM   #6
show7ime
show7ime's Avatar
Drives: 2017 1SS Summit White
I spent countless hours watching exhaust videos for the 6th Gen. Enough that people around me would roll their eyes because I was so indecisive. In the end I went with SLP and got the exhaust note I wanted and am 110% satisfied. On the flip side I could have went to an exhaust shop to do a custom job, but didn't want to run the chance of a poor job properly crafting the pipes.
If curious, I did post clips of the exhaust on my Instagram: ggShow7ime
Sponsor: SLP Street Legal Performance
show7ime is offline   Reply With Quote
Old 08-18-2017, 04:39 PM   #7
Marty McFlew
Drives: 17 SuperSport Camaro 6 on the Flo'
I've got NPP.
Marty McFlew is offline   Reply With Quote
Old 08-18-2017, 04:52 PM   #8
SilverSixGen
SilverSixGen's Avatar
Drives: 2016 Camaro SS
I 've got that exact set up that you're looking for and its great IMO. I started with just the headers connect to my NPP setup then after deciding it wasn't loud enough for me I got the MBRP race version catback. It could be slightly louder but the tone is great, deep and loud at WOT. Only other option I would have opted for would maybe be replacing MBRP with corsa, but I'm happy.....for now
SilverSixGen is offline   Reply With Quote
Old 08-18-2017, 06:26 PM   #9
enzia35
Drives: '16 Garnet Red 1SS
I too, love hookers.
'16 Camaro 1SS
'18 Miata GT
Old 08-18-2017, 06:38 PM   #10
Zzzato
Bigg Balls
Zzzato's Avatar
Drives: 2017 Red Hot 1SS
Seems some of the most common you'll see here are the borla, hookers (exhaust, not ladies of the night), and mbrp there's also a KOOKs system out there haven't heard that one on any clips. Then there's the whole diverter/ cutout route which some will save some money and get you some good sound, loud albeit. If you're going for loud, diverters, if you're going for an all in one package that's not setting off all the alarms in the parking garage,vbut will have some gains in hp go with a full system cat back secondary cat delete. Phastek is a good site to check out as well as the many other references on here.
Zzzato is offline   Reply With Quote
Old 08-19-2017, 12:42 AM   #11
Marty McFlew
Yeh...I had Hookers on my 69 RoadRunner.
Old 09-25-2019, 08:19 PM   #12
My First Camaro!
My First Camaro!'s Avatar
Drives: '18 5.7 RAM 1500 18' 1SS
2" will loose nothing under the curve and flow a bit better at 6K+. The only reason to go 7/8 is possible cost, fitment, quality of construction. If all 3 of those are the same, go 2".
JRE Tune
My First Camaro! is offline   Reply With Quote
Old 09-25-2019, 08:30 PM   #13
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
The best you can get is my exhaust post I just updated
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
Old 09-25-2019, 08:59 PM   #14
Juiced1
Drives: 2012 2SS CAMARO 45th
If you like the sound of your Stainless Works catback I would just add a set of Stainless Works headers. They have a connection pipe available that will allow them to bolt right up to your catback and give you a true 3" system.
Since the 6Gen doesn't have a connection point you have to watch what you pair up together. A lot of systems overlap and will require cutting/welding.
When you're ready to order stop by our site and shop around with code CAMARO6 or give us a call and we'll make sure you get the best price.
Juiced1 is offline   Reply With Quote
