09-27-2020, 07:51 AM | #1 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Cam fuel lobe lift question
Anyone know what the stock cam fuel lobe lift is? Was comparing BTR, TSP, and Cam Motion cams and the 1st two use a %(38 &. 32), but Cam Motion use an actual lift number.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
09-27-2020, 09:21 AM | #2 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
I also researched this question, from what I found/or converterd, the Cam Motion is also 38%
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
09-27-2020, 09:56 AM | #3 |
Thanks, be nice if they compared it the same way.
09-27-2020, 01:04 PM | #4 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I’m running cam motion stage 3. As great of a cam as it is I wish I went with stage 2 just to keep better normal driving. The stage 3 tend to buck a bit more coming to lights than I prefer.
09-27-2020, 01:51 PM | #5 |
38% fuel lobe? I guess u are running stock converter?
09-27-2020, 08:59 PM | #6 |
09-27-2020, 09:06 PM | #7 |
I looked into adding the Circle D converter, but it's 2k plus labor, so Im still thinking stage 2 cam. I am dropping off the car tomorrow and will discuss it again.
09-28-2020, 09:51 AM | #8 |
Dyno Show Queen LOL
The factory goes by millimeters...
Stock LT1 fuel pump lobe size 5.70 MM Stock LT4 fuel pump lobe size 6.00 MM 32% Fuel Lobe 6.5 MM 38% Fuel Lobe 7.5 MM 42% Fuel Lobe 8.2 MM (LPE Big Bore Pump only) The LPE pump is only good for a bout 10% more fuel than a LT4 with that 6.00MM lobe and for some reason that's how its advertised. When you use there GT35 or GT32 cam with the 8.2MM or You can have BTR or Comp Cams cut a 42% then the pump is 30 to 40% better.. this is one of the areas that people screw up and do not meet there fuel needs when they buy the LPE pump.
09-28-2020, 10:48 AM | #9 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
EDFHOBBIES: Good info! Thanks.
09-29-2020, 09:06 AM | #10 |
Dyno Show Queen LOL
Anytime..
09-29-2020, 09:27 AM | #11 |
Drives: 2019 SS Join Date: Apr 2020
You need a trans tune if it's doing that, the converter need to be locked at lower speeds.
09-29-2020, 09:28 AM | #12 |
What is the LT5 cam's fuel pump lobe?
2016 NFG 1SS A8
09-29-2020, 10:10 AM | #13 | |
09-29-2020, 12:51 PM | #14 | |
I agree, it would be much easier if they would list the % also. Which cam are you getting? I will order this one soon: Gen 5 LT/PD 220/236 Positive Displacement Supercharger Camshaft (220/236-118+4) I want something mild, I might even have them grind it on a 120 LSA for a even smoother idle.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 Last edited by swisstyphoon; 09-29-2020 at 01:02 PM. |
