08-13-2019, 10:14 AM | #1 |
Drives: 2019 2SS Join Date: Mar 2018
How to prevent AFM valves CEL
I have a A10 2SS and I am planning to get rid of stock exhaust and secondary cats. As far I know borla 60610 and SW have AFM valves but I don't want to spend that much dough. I already have a range disabler so I don't use afm anymore and unfortunately I can't tune it out because of warranty.
I read about EFI tuning afm valve delete module but their website isn't working. Is there any another possible solution? Can I just remove those actuators from stock exhaust without cutting and zip tie them under the car? Would it be wonky? |
08-13-2019, 10:16 AM | #2 |
Drives: 2016 Camaro SS Join Date: Sep 2018
If you remove them it throws the code, you either have to tune them out or zip tie them under the car.
08-13-2019, 10:35 AM | #3 | |
08-13-2019, 09:52 PM | #4 | |
Drives: 2018 Camaro 2SS Join Date: Jul 2019
2018 2SS - Unmodified
08-13-2019, 10:29 PM | #5 |
If you shut them off with HP Tuners, then you don’t need the valves at all..
08-14-2019, 12:33 PM | #6 | ||
My car is my daily driver so my concern is how they are gonna hold up being exposed like that. Also is there actually any appropriate room around the undercarriage to mount/zip tie them? |
08-14-2019, 12:41 PM | #7 | |
Sent from my SM-G955U using Tapatalk |
08-14-2019, 12:48 PM | #8 |
Drives: 2019 SS 2019 mustang GT Join Date: Apr 2017
08-14-2019, 01:10 PM | #9 |
Drives: HB 2SS Join Date: Apr 2017
You can zip time them away. Stainless works has a really good solution where it just mounts it to nothing and there's no valves inside the X-pipe. Probably the cleanest solution asides from actual AFM exhausts.
08-14-2019, 06:37 PM | #10 |
I guess I will be going Plastic bag and zip ties route.
What about NPP harness/connection? Wrap them with electrical tape and zip tie them away? |
08-14-2019, 07:29 PM | #11 |
Yep, that's exactly what I did.
12-25-2022, 05:39 PM | #12 |
I tried to pulled the AFM fuse after plugging in the range device, but is till got a CEL prob cause of the fuse. I’m okay with buying the range device but I don’t like to keep the actuators plugged in and zip tied underneath the car. Any solutions?
12-25-2022, 05:59 PM | #13 | |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
, sell half price.
2023 ZL1 A10 Shadow Gray Metallic
