02-28-2015, 10:02 PM | #1 |
Drives: ‘13 1LE Join Date: Jul 2013
Need Wideband, Dashlogic or Aeroforce?
All of the additional bells and whistles are fine, but all I really want is an accurate and permanent Air/Fuel Ratio display, and yes it will be used for remote tuning purposes as well when it is called for, like when I'll be data-logging and monitoring AFR after cam install.
I do like the Dashlogic's audible chime feature.... I own a SCT X4, but I did not buy the provision that it needs for wideband data-logging. I think that it would be best to just buy a really nice permanent gauge? Thoughts/recommendations? |
03-02-2015, 10:26 AM | #2 |
Geek
Buy the analog input hardware you need to log the wideband and get a good permanent gauge. You'll be happy with yourself after you have forgotten that you spent all that money.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
03-02-2015, 04:30 PM | #3 |
I was afraid that you would say that!
Done, I'll order the analog input hardware for the SCT asap. As for permanent gauge, still on the fence though...I think I will go Dashlogic just for the audible chime capabilities. |
03-03-2015, 06:19 AM | #4 | |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Definitely spend the extra cash, as for AFR, I like my Innovate digital. I keep the output from the wideband in my glove box for datalogging.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
03-21-2015, 01:08 PM | #5 | |
Yeeeeears back, I used the Innovate LM-1(remember those clunky units? ), and was quite pleased with it, it did the job back then.. One thing is for sure, and this may very well mark the first time I will bad mouth a product on this forum, but I am staying away from Dashlogic . They have zero phone support as in literally none, and their email sales guy was about as useless as they get, dare I say, borderline insulting.. I mean, I'm almost tempted to show on here our email chit chatter, but that_would_not_be_my_style. Anyways, I digress, the hell with Dashlogic, customer service is more important to me than the product itself! Sooooo, I'm shopping around now for a more traditional wideband gauge for AFR measurements, in order to catalog WOT with my SCT X4, although I'm not keen on cockpit clutter. That said, I guess a AFR gauge with excellent aesthetics is now paramount. Any recommendations would be appreciated, AEM, Innovate, Aeroforce....I have 4 weeks left to make a nice choice. FWIW, I will be using the secondary O2 sensor bung hole for a permanent installation of the wideband O2 sensor, since I'm using off-road pipes. |
03-21-2015, 02:47 PM | #6 |
I also had experience with the LM-1 when I worked as a mechanic years ago. I bought the Innovate because it for sale for a great price from a member on C5. I had the opportunity to change it a while back and decided to keep it because I was happy with its performance and it will read as fat as 7.35 AFR. Most others will only read as fat as 10.
03-22-2015, 02:55 PM | #7 |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
I just installed an Innovate LC-2 and wired it to the Analog Input on the Dashlogic and the SCT X4 Firewire cable for Datalogging. It works very nice and hides completely.
03-22-2015, 10:37 PM | #8 |
All right, thanks a lot guys, I have decided what to go with
I went with the latest rendition of the AEM UEGO. It's not what I initially had in mind, but the black bezel(my interior has been custom repainted by a forum member) of the AEM will match beautifully! I also like that the AEM doesn't need that manual free air re-calibration every so often. Installation seems to be straight forward with this unit, and reviews some to be quite good as is pricing. |
03-29-2015, 09:01 AM | #9 |
Drives: '14 ZL1, Duramax H2 Join Date: Apr 2012
A little late in responding but I went with Aeroforce mainly for looks but also for the display options like scrolling graph and logging capability. A/F is on the left gauge, bottom parameter.
Todd |
03-29-2015, 11:11 AM | #10 |
I am not "Fast & Furious"
Drives: 2010 Camaro LSX454 1LE Join Date: Nov 2008
That's a cool gauge pod, where did you get it?
The day I take a bend too fast
Judgement that could be my last I'll be wiped right off the slate Don't wait up 'cause I'll be late, I'll be late |
