08-09-2019, 10:28 PM | #15 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
not at all.....what it does is it turns iron oxide (rust) to chemically change to iron phosphate an inert, hard substance that turns the metal black.
08-09-2019, 11:50 PM | #16 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
I soak anything rusty in red apple cider vinegar. Chemically removes rust due to extreme pH and safe to handle. I either use a glass jar or soak a rag/paper towel and wrap the object.
Good on french fries too.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
08-10-2019, 07:21 AM | #17 | |
Drives: '16 Z06 7 Spd, 2024 High Country HD Join Date: May 2015
08-10-2019, 11:39 AM | #18 |
Drives: 2010 Join Date: Dec 2018
what I found
08-11-2019, 08:33 AM | #19 |
although its an acid....what you get sold is in diluted form, and like with ANY chemical of any kind...you certainly don't want to put it in your body. it certainly can/will irritate your eyes, that's for sure and like with ANY chemicals should be used in well ventilated spaces.
granted, evapo-rust is TOTALLY biodegradable, and doesn't/shouldn't cause any problems in your body. it looks to be what you need for your application.
08-12-2019, 02:35 PM | #20 |
Drives: 2012 45th Anniversary Edition Join Date: Aug 2012
08-12-2019, 05:26 PM | #21 |
Drives: 2015 SW 2SS 1LE Join Date: Jan 2018
I know, but I'm pretty sure he drinks Bud Light
Maggie 2650 @ 18psi/ 75mm 10 rib/ Dual alky nozzles/ Roto-fab/ ARH 2" Lt's/ GT-12 cam/ ZL1 3.23 Conv./MGW/RPS triple carbon clutch/RSG tranny upgrage/Pedders Ex. XA w/ remote cans and a lot of other crap 897/8??@tires
08-12-2019, 07:23 PM | #22 |
Tri-County Camaro SWFL
Check this out. Guy does a lot of videos of different things. Heres one comparing evaporust
https://youtu.be/6-MC_ZEXQbw
08-13-2019, 09:37 AM | #23 |
08-16-2019, 08:50 AM | #24 | |
08-16-2019, 09:08 AM | #25 |
Drives: 1991 Z/28 Convertible Join Date: Feb 2018
That stuff is awesome!!!!! Not a bad price either.
https://www.jegs.com/webapp/wcs/stor...rsistYmm=false |
08-16-2019, 09:28 AM | #26 | |
Thread Tools | |
