09-01-2018, 11:38 PM | #1 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Brake Lines PSA
EDIT: IF YOU HAVE AN 1SS/2SS 1LE Please purchase, Goodridge 12440
All brake line kits that claim they fit the SS/ZL1 calipers will not fit our front (SS1LE) calipers. The Banjo Bolt on our front calipers is on the bottom and not on the center like SS/ZL1 calipers. Just a heads up. We also share front calipers with ATS-V and C7 Z06 Corvette uses a completely different line. The ATS-V line appears to be the same. The rear lines are all the same between SS/SS 1LE/ZL1/ ZL1 1LE Edit: Goodridge 12299 Kit: Front lines will not fit the SS1LE. Rears will Fit all 6Gen V8 models. Front Brakes 1SS 1LE Front Brakes ZL1 1LE Front Brakes Corvette Z06 Last edited by thescreensavers; 01-09-2020 at 08:02 PM. |
09-02-2018, 06:39 AM | #2 |
Drives: ISO ss 1le Join Date: May 2018
Good to know, I was thinking of doing SS brake lines.
DO you have a ZL1 1LE, or did you get the DSSV's for your SS? I'd be interested in hearing the story on that! |
09-02-2018, 09:29 PM | #3 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
The brake lines not fitting is to be expected, the ZL1 and the ZL1-1LE have a different caliper than the SS 1LE uses.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
09-02-2018, 09:35 PM | #4 |
Drives: 1LEs Join Date: May 2009
The rear flex line is the same between SS 1LE and ZL1 / ZL1 1LE.
09-03-2018, 03:13 PM | #5 | |||
C7 Z06 had the same issue when it first came out until they made a line specific for the iron rotor Z06. Last edited by thescreensavers; 09-03-2018 at 07:07 PM. |
09-09-2019, 01:51 PM | #6 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
Hi - so, what does fit SS W/ 1LE from Goodridge? Or any good complete kit out there?
09-12-2019, 09:18 AM | #7 | |
Drives: 2016 1SS Join Date: Jun 2018
Was just looking into this today... I believe it's these: https://wildhammermotorsports.com/16...kit-goodridge/ |
09-12-2019, 10:45 AM | #8 | |
I wonder if Wildhammer is packaging this themselves by combining other Goodridge kits, like an ATS-V fronts with the SS rears?
09-19-2019, 09:43 AM | #9 |
Drives: 2017 Camro ss 1LE Join Date: Jul 2017
IM NOT SURE WHY IT HAS TO BE SPECIFIC TO THE 1LE BUT I BOUT A KIT FOR THE ZL1 AND HAD THEM INSTALLED THRU A SHOP .. WITHIN 3 MONTH THE FRONT RIGHT BRAKE LINE KINKED AND LEAKED ALL OVER THE RIM. SO PLEASE MAKE SURE ITS SPECIFIC TO THE 1LE..
09-19-2019, 11:30 AM | #10 |
Drives: 16 GMC Denali Dmax, 14 1LE, 10 SS Join Date: Jul 2015
Goodridge part number 12440. Made specifically for the SS 1LE
09-19-2019, 12:37 PM | #11 |
Drives: 2018 SS 1LE Join Date: Apr 2016
Good to know. Front brake lines are the same for us SS 1LE guys with the current gen Z06 and ATS-V guys.. as known when ordering brake pads as well.
Rear brake lines and pads are the same with any GEN 6 SS.. Is that a true statement??? So I know from this post and several other posts. |
09-19-2019, 01:01 PM | #12 |
Who Needs to KNOW?
Why change ? Stock lines are steel reinforced.
Create whole new series of problems - abrasion of near by items, Often missing OE type mount brackets.
ing for grip.
09-20-2019, 02:32 PM | #13 |
The goodridge lines are far superior to the OEM lines and have provisions for all OEM mounting, including the mounts for the ABS wiring. I helped a friend install a set on his 17 SS 1LE and the fitment is perfect and the pedal feel is far superior to the original lines. They also state that the new lines are DOT approved and have a lifetime warranty. I would not hesitate to install a set again.
09-20-2019, 03:18 PM | #14 |
Who Needs to KNOW?
Nah, its just case of lighter wallet = faster car
ing for grip.
