03-26-2017, 09:43 PM | #29 | |
Drives: 2006 Pontiac GTO Join Date: Jul 2015
Somone in a bolt-on C7 has dipped into the 10.4s@129mph |
03-26-2017, 10:10 PM | #30 | |
Drives: 2012 Mustang GT, 2017 Camaro 1SS Join Date: Mar 2017
To run FTW with the Coyote you need larger injectors and a BAP to handle the amount of extra fuel needed. Back OT...the converter should be worth .4 and I am very interested to see how it works on the 6th gen. We bought my wife a 2017 1SS and have the converter lock shudder issue. I am torn on replacing the converter and getting a tune or just keep it under warranty. I already have a car to take to the track..... I have been following Pray's progress and am impressed so far...especially with the stock converter. |
03-26-2017, 10:25 PM | #31 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
I said s550. Looking at my post now I can see how it looks like I meant all. Did you even remove your windshield wipers? |
03-26-2017, 11:41 PM | #32 | |
The only thing that it lacks to be street worthy are mufflers and windshield wipers. I may just put those back on just to say it is. Apologies but I don't want to distract from the thread too much. I am very interested in how the 10 sec., N/A chase turns out. Here are some pics of the wife's car: It may just get a TVS and call it done......I can't leave anything alone. Last edited by wbt2012; 03-26-2017 at 11:57 PM. |
03-27-2017, 01:12 AM | #33 |
Nice
Looks exactly like my car |
03-27-2017, 12:55 PM | #34 |
Drives: 2016 2SS Join Date: Jul 2016
Now if we want to compare cars mod for mod to see which is truly the better platform then we need the no crap weight of your car going down the track and the DA you ran those times in. I would also have to go on pump gas or you go on pump E to see which car is truly faster. I am assuming I would have to add some mods to my engine combo or drop some to be truly mod for mod even. I am not really interested in that argument though. I don't own a Mustang and have no interest in how fast they are. Not trying to be a jerk but I don't build or offer parts for Mustangs. I am only interested in making my car go as fast as humanly possible with the least amount of mods and the smallest deviation from how I drive it every day. It does me no good to lose on the street from a roll or at a stop light and tell a guy that it runs 10's, on E, with my drag pack, in - DA, with my seats out, and my exhaust dropped. Kind of like saying if I had my bottle turned on I would have won. Well, you didn't, you lost, so deal with it. No if's in chance encounters. So please, since you have drag racing nailed down in bolt on form, add to the conversation anything you think will help the cause. It is appreciated and welcomed.
03-27-2017, 02:24 PM | #35 | |
My raceweight sits at around 3,270 depending on how much fuel I have in the car, never more than 1/4 tank. The times posted were run in sea level air. I wish Texas had better to offer but unfortunately we are just too far South here. I had MS109 in the car on those runs and I run the same timing on that fuel vs. e85. No real difference in power. Since I had the stock fuel system components in the car that was the best I could do. I lent my injectors out to a TVS car I also tune so was stuck with the stock injectors for about a year. Additionally I believe the MPH in the 1/4 was off on those timeslips based on my logs. I was seeing 129 there but we will have to go off the timeslip. Onto the converter, in the Mustang it is worth about .4 over stock so I would expect similar gains with the A8 however I will say I am very impressed with the stock A8 converter and the 60' times it allows for. 1.8 is about the best one will see with the stock converter in the Mustang. One main item I am interested in is converter lockup. On the Mustang side the fast cars lock it up right after the 1-2 shift and try to get through the 1/4 mile in the top of third. I have to wind my car our to 8K to make it through. I am interested to see if locking it sooner would also benefit the A8. Do you do your own tuning? If I recall you may do some and collaborate with others as well. |
03-27-2017, 05:34 PM | #36 | |
I figured E85 would make more power than race fuel due to the cooling effects. I didn't think it would allow for anymore timing or octane though. I am hoping the converter is worth .3. Talking to Chris he was thinking .2 and possibly .3. The stock converter will "flash" to 2,700ish and hold there for quite a while before the rpm climbs. I think I will see .3 due my dyno graphs. If I can blast though the soft spot and come up on power I should be able to hit high 1.4's. We are only talking about a gain of 1K rpm over stock or so with the converter I got. I also heard that since the gear split in the A8's are so tight that the converter doesn't help so much. That remains to be seen. Below is the launch vs. the dyno graph. It kind of lays out why the 60ft and 1/8th could be a ton better in this car. I do lock the converter as soon as it hits 2nd. All of my drag race buddies do their best to lock the converter as soon as it hits 2nd as well. I am sure the billet 248 will work the same as the stock converter and it has a third clutch so I will be more than fine with my power level.
03-27-2017, 08:07 PM | #37 | |
Drives: 2013 SS Join Date: May 2013
Sir does this mean you may tap into GM?
03-27-2017, 08:40 PM | #38 |
I forgot to mention that I have been doing all of my own tuning for the last 13 years. I started out tuning this car on my own after some help from friends in the industry and tuning a C7 that set the bolt on pump gas record in 2015. The actual only real reason I got this car was to nail down the tuning. I don't do stuff to other peoples cars before I do them to mine. (the C7 was a real good friends that I used to do work for). I got this car going pretty well but since I use EFI Live I wasn't able to do E85 Tim of EFI Tuning stepped in. He dropped a prototype kit on my car and set up the tune to work. He turned me loose on it to get it dialed in for my combo. Then Tim figured out the TQ tables and put those in my car as well. I do all the on street and track tuning. I have it all worked over now and the TCM for my set up. I am begrudgingly making the switch to HPT but I am not impressed so far in the least with it. But they are keeping up with the time and so must I.
03-27-2017, 09:24 PM | #39 | |||||
There is also a trick to wire in an electronic tbrake. It basically uses two solenoids wired into the PCM that when active, engage two forward clutches creating a bind. Used in combination with the two step launches are as simple as releasing the button. Quote:
On the Camaro side, when I drive my wifes car I can tell they have TQ mgmt heavily controlling everything. My bet is getting that out of the way would create a monster. I am eyeing an e85 setup for her car as well but I need the ability to switch tunes so she can switch if I am not around. Looking at nGauge support for the LT1 there. Thanks for entertaining my questions. I have been lurking following your progress for awhile and am very impressed. These cars have so much more in them vs. what the factory delivers. |
03-28-2017, 04:49 AM | #40 | |
The junk GM did with the 17's is rediculous to keep people out of the cars. Especially the TCM. That kind of tells you what they are affraid of. TM is everywhere on these cars. Tim has cracked to code on how to tune these things. There are tables that have to be adjusted first before the rest of what we normally do will have any effect. On the E85 bit you will only need one tune once you have the flex sensor in there. She can bounce back and forth between E and pump with no ill effects. Looking at your slips again and thinking about the 5.0's I have seen at the track it makes mores since that you were trapping 129 on the top end. The 5.0's need much more gear and a large converter to get out. But they top end like a big dog for sure.
03-28-2017, 11:11 PM | #41 | |||
Here is where I ran that time.....race from a bit over a week ago (DA was 2,200+): |
03-29-2017, 07:15 AM | #42 |
I have a buddy with a S550 that has a 5C, gear, IM, CAI, headers w/ full exhaust, drag pack, on E fully tuned. The car is full weight other than that. He picks up a solid 25mph on the top end. We ran on the same day in same weather at different tracks that are pretty close together location wise. His 60ft was a hair better than mine and the overall ET's were only a couple tenths apart. But I had 3mph on him in the 1/8th and 4mph on him in the 1/4.
