05-31-2018, 01:09 PM | #1 |
Drives: 2016 Camaro NFG 1SS A8 Join Date: Oct 2017
No change tranny filter?
Stopped by a chevy dealer today to inquire about a transmission fluid flush and filter change and they (Bommarrito Chevrolet in south county) specified they do not change the filter (don't drop the pan he said). I know it has a filter (I've seen it) but I was told it's more like a screen (making it sound like it's insignificant). My question is, is this the norm? Do dealers or garages not change the filter on these trannies? By far, my biggest complaint about this car is they make it a real PITA to service the transmission yourself............Nobody cares about your car like YOU do!................GRRRRRRRRRR!
05-31-2018, 01:21 PM | #2 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Just remember, the new stuff can't escape science; meaning, new or old, you will have wear and tear. The intervals may change, but there is no such thing as a true "fill for life" when you take a closer look. Yeah, "fill for life" if you drive A-B and THAT'S IT. Outside of that, no, maintenance should be done.
05-31-2018, 01:23 PM | #3 |
I would listen to them. I wouldn’t touch the transmission. They say life because we all know what usually follows new trans fluid.
06-08-2018, 12:37 PM | #4 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
they changed it when they did the triple flush on my car, so that says something to the issue.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
06-08-2018, 01:35 PM | #5 | |
Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
This is just your dealer of choice taking the easy way out when doing a flush service. They just hook up the BG machine and push fluid. No pan drop or anything. The trans def has a filter that should be serviced like every other vehicle. In fact the 2.0, 3.6, and 6.2 use the exact same part number. They should: Drain, Clean pan/magnet, Replace Filter, & Remove fluid from the oil cooler lines. Especially if you have a shudder concern. I would tell you to bring it up to my dealer, we will hook you up, but we are about 65 miles west of Bommarito South.
06-20-2018, 04:53 PM | #6 |
Thanks Coop but you guys are a little far for me (South County)......Went to George Weber Columbia and they did me real good.........
