Old 04-22-2018, 07:56 PM   #1
kaydoe
Drives: 2017 Camaro 2ss convertible
Stock stall rpm?
Does anyone know what the stock stall speed is and the stall of the
Gm performance converter?
Would be for a LT1 A8.
Thanks Chris
kaydoe is offline   Reply With Quote
Old 05-09-2018, 06:48 PM   #2
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 06-24-2018, 05:50 PM   #3
kaydoe
Still don,t know about stock but GM performance says 4500 on the on theirs
Old 06-25-2018, 04:37 PM   #4
ULTRAZLS1
ULTRAZLS1's Avatar
where did you find that?
all I see is 45% more
does anyone know anyone running the gm stall?
Old 06-25-2018, 06:26 PM   #5
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
You own a camaro..... go out and find out where your stock one stalls to. That's like asking what the speedometer goes up to in your car.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 06-25-2018, 07:47 PM   #6
JRS
JRS's Avatar
Drives: 16 camaro M6/ 18 ZL1 camaro A10
I don't know the stall speed on a A8 but like danhr said it's easy to figure out. Just stand on your brakes and give it gas until the rear wheels start to spin, whatever rpm that is that's your rough stall speed is. It's probably close to 2500 rpm.
JRS is offline   Reply With Quote
Old 06-25-2018, 07:54 PM   #7
kaydoe
(where did you find that?)
Trying to find where I read that at.
Chris
Old 06-25-2018, 08:02 PM   #8
JRS
JRS's Avatar
If your asking me I didn't read it anywhere but I'm sure you could do a google search. This is just a simple way to check your stall speed because basically the idea is you loading the engine up and what ever rpm starts to spin the tires under full load is where the torque converter stops slipping and tries to stall the engine down.
