Old 04-12-2018, 03:18 PM   #1
retmil
Drives: 2022 Wild Cherry SS
Second gear shift issue
I am having an issue when shifting from 1st to 2nd in my '17SS. Going into 2nd gear is very "notchy" but when downshifting I have no problem. Rest of the gears are OK. Any ideas?
retmil is offline   Reply With Quote
Old 04-12-2018, 07:34 PM   #2
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
It’s all in the fluid. Swap it out and that will less/go away.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 04-13-2018, 03:34 PM   #3
retmil
Thanks - I was thinking that.
Old 04-13-2018, 08:28 PM   #4
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
If it's when it's cold, that's normal. If it's notchy when warmed up and the clutch is ALL the way in, then I'd have the dealer check it.
torqueaddict is offline   Reply With Quote
Old 04-24-2018, 01:04 PM   #5
4door65guy
Drives: 2016 2SS MAG/NPP
what fluid do you recommend for the M6?
4door65guy is offline   Reply With Quote
Old 05-01-2018, 05:25 PM   #6
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I'm having the same issue but mine is 2nd to 3rd shift and that's when it's hot an when I need it most! Be careful using a non-GM approved fluid if you take it in, they may check
Old 05-02-2018, 04:46 PM   #7
mike'SS
mike'SS's Avatar
Drives: Gen 6 Camaro 2SS M6
I remember someone on here mentioned the Royal purple fluid for the M6.
mike'SS is offline   Reply With Quote
Old 05-02-2018, 04:55 PM   #8
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
I'm having the same issue with 2nd to 3rd when the car is hot, like it doesn't let me in :(, hopefully changing the transmission oil does the trick.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 05-18-2018, 11:40 PM   #9
bub
Drives: '17 1SS 1LE & '15 Corvette Z06
Same 1 to 2 issue here just cropped up. Read that early TR6060 had 2nd gear synchro issues, but assume this is remedied by now...
I'm starting with dealer b4 any fluid etc.
Hate to do it but probably have to remove CAGS bypass before taking it in.
bub is offline   Reply With Quote
Old 05-21-2018, 06:02 PM   #10
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I felt the same way with mine. As soon as I hit 1500 miles, the fluid came out and the royal purple went in. It shifts much smoother now, even cold. I bought the fluid and had the dealership do the fluid swap as I didn't have jack pads at the time. They charged me around $120 for tranny, and $80 for my rear diff. Aftermarket Rear diff fluid is iffy from my understanding, so I just kept the stock fluid. I put redline in my other car(frs), that stuff is amazing as well, but it's a completely different transmission. Both work great and I'd recommend both, from my research, Corvette owners loved the purp!
Old 05-24-2018, 04:45 PM   #11
carguy55
carguy55's Avatar
Fixed my shifting problems with a fluid change, now it's like butter. No more wondering if it will go into 3rd or not on track at WOT
Old 10-19-2018, 03:51 PM   #12
retmil
I switched trans fluid to Royal Purple a couple of months ago and no improvement in 1st to 2nd shifts unless I shift at over 4K rpm. Don't really want to rev that much just to shift. Any ideas? Thanks
