12-30-2019, 09:35 PM | #1 |
I purchased Carlyle Racing LT4 Short Block for my replacement
Well I took the easy way out and purchased a Lt4 short block with only 1500 miles. It was replaced with a 416 and I'm the beneficiary which makes me happy. Should be an easy swap and hopefully have it running by the end of January and ready for the track in March. Lower the boost, run different fuel, pull some timing, lower my shift points and actually enjoy going to the track and just try to make around 800 rwhp with a safe tune. I'll get the old motor torn down and will probably sell the Manley Forged Pistons and Rods. I'll also install the Arp main studs out of my motor. I could probably have the Lt1 lined bored and put it back together with a crank that I picked up a few weeks back.
12-31-2019, 08:03 AM | #2 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Good deal, Greg. You should be back up and running in no time! The stock LT4 crank is slightly more robust, and apparently the stock pistons and rods are good for anything short of 1000 who or so, in fact, I haven't heard of any LT4 failures that were not oil pump related.
Baby Blue
12-31-2019, 08:52 AM | #3 |
They are pretty stout and saves me money in the long run. I agree, haven't hear of one either.
12-31-2019, 09:35 AM | #4 |
You gonna do something with that half thrust bearing? There have been some failures( per CSP )as of recent above 800whp due to that piece.
2016 NFG 1SS A8
12-31-2019, 09:55 AM | #5 |
I might and I know that LME has a replacement for it and same issue on the LT1s
12-31-2019, 10:28 AM | #6 |
I think we are going to limit this motor to about 800 to be safe. This short block only has 1500 miles on it so should be good for a long time at that HP level. Gonna be a fun year and not trying to even better my best et, don't really care anymore. Just going to try and be around the 9.50s and work on my reaction times and go some rounds instead of breaking shit and loading up and going home. Wife is tired of that also.
12-31-2019, 03:20 PM | #7 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Great news. Hope you got a good deal on it.
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
12-31-2019, 03:41 PM | #8 |
I did, I'll keep everyone up to date once I get it and put everything back together.
12-31-2019, 06:24 PM | #9 |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
Good luck.
I shall also be following your updated (re)build... |
12-31-2019, 07:06 PM | #10 |
Its been a rough 15 months so maybe this will be the route that keeps everything together for a while. Happy New Year to all.
12-31-2019, 08:01 PM | #11 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
Yea I know how ya feel. I'm on my second engine build within a year on this car and I haven't even thrown any boost at it yet. Best of luck to ya and Happy New Year as well.
01-01-2020, 06:36 AM | #12 |
Hey Puddin, what kind of problems have you been having?
01-01-2020, 11:58 AM | #13 |
Horsepower whisperer
Drives: Camaro Join Date: Jun 2017
What’s the fix for the 1/2 thrust bearing? I looking at the clevite main bearing set and was like wtf? Am I missing a bearing half
Btw the clevite thrust bearing is much more robust than the spot weld oem piece Last edited by Goohead; 01-01-2020 at 12:15 PM. |
01-01-2020, 12:08 PM | #14 |
First time I lost oil pressure while doing some street pulls for Pray and the second time I had a set of PRC heads that were leaking inside some of the runners and hydrolocked the motor. The worst part about the whole hydrolocking ordeal was that I just had my set of GPI drop ins put in the month before. After having my shop pull the motor we found some rods were bent pretty good so I had to start over once again. I will say that TSP did step up and owned their mistake with the heads which lead to us coming to a deal on a 427.
