03-07-2022, 08:51 PM | #1 |
Drives: 21 Camaro convertible 4cyl turbo Join Date: Sep 2021
4cy 2.0 wont start
Hi, all hoping for some help. I bought this conv camaro 2021 model with driver side damage. It drove off the transport trailer and idled while i signed paperwork. It then died. I assumed out of gas. After weeks of it parked I have tried fuel pump, changed the plugs as they were gas fouled. It cranks very good. its a 2021 4cyl turbo camaro and hoping I can get some help.
On another note I need some headlghts as I put z28 nose on it. |
03-08-2022, 09:58 AM | #2 |
Drives: Chevy camaro Join Date: Jul 2019
Warranty?
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, goodrich comp sport 2s 275/35/20 rears, fifty brembos front, 13.6" slotted and drilled powerstop rotors |
03-08-2022, 03:29 PM | #3 |
Drives: 2014 Cadillac CTS4 2.0T Performance Join Date: Sep 2019
I do believe it is a salvage vehicle based on the description. Warranty will not cover it.
Honestly, buy a set of manuals, especially the electrical and spend some time going through all the circuits... There are FAR too many possibilities as to why it is not running. There are no pictures, so damage assessment is impossible. I take it you are a business that rebuilds cars for a living? This is based on the "broker" part of your username. If so, then shouldn't you be adept at actually "fixing" the cars you are making money on? Sorry, been there, done that in regards to helping people just to find out they were fixing and flipping the vehicle. If you are making a buck off it, do your own work, don't ask others to fix something for you. You aren't offering to share the profits. If you are not flipping it and going to keep it, then the same thing applies. You should get to know your own car in case you are stuck somewhere and something goes wrong. Or, do the RIGHT thing and pay a professional to fix it. It will hopefully be done right and you won't have to worry about making sure all the details are done. Far too many people take advantage of others. It wasn't like you wrecked the car, you got it at a huge discount because someone else did. That discount comes with the price of needing to fix it. |
03-08-2022, 07:36 PM | #4 |
HI, being rebuilt no warranty will be given. The broker in my user name was stock broker i now sell insurance. I do buy cars and trucks to drive and will sell if someone wants them. I was hoping a camaro forum has experts that would help . My local mechanics are just wanting to change parts in hopes it solves the issue. IF this is wreck related then no one would have the same issue. I just dont know how a car runs , dies then will only sporadically start. Is there a better place to ask? Thanks
03-14-2022, 12:20 PM | #5 |
Drives: 2018 LTG Camaro Join Date: Dec 2021
You just need to check basics. Does it have any DTC's? Is it firing on all cylinders? Does it have consistent fuel pressure while running and starting? Can you do a compression test?
03-14-2022, 12:40 PM | #6 |
Who Needs to KNOW?
Crank, no start. Sounds like easy fix. Check codes, and go from there. Since wrecked, wiring damage.
ing for grip.
03-14-2022, 01:32 PM | #7 |
Thread Tools | |
