05-22-2015, 07:53 AM | #1 | |
ECS supercharger, is this normal?
Here's a video i made a few weeks back of my supercharger making a rattling noise. The oil is full, and i cant see it vibrating against anything. It hasnt always made this noise. I have had it on for 11 months, its been making the sound for about 6. The supercharger seems like it still performs just fine, and I havent heard any others doing it.
thanks
2010 Camaro 2SS/RS LS3
1093/1066 416, AGP 6262, E85, Cam |
05-22-2015, 08:35 AM | #2 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Take the air filter off and make sure the restrictor plate is still intact and impeller is ok if u havent already.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
05-22-2015, 08:59 AM | #3 |
Ill go check that in just a bit. would that cause any boost issues as far as spiking over where it should be or not building it? cause it seems like it still functions normal.
05-22-2015, 10:00 AM | #4 |
Drives: 2010 Camaro SS Join Date: Aug 2013
The restrictor is two parts...a rolled ring (with a split) and a flat "washer". They are tack welded together and if mine is any indication...they are poor quality welds! I could easily believe yours has come apart.
05-22-2015, 10:02 AM | #5 |
Mine did come apart and tore up the impeller.
05-22-2015, 10:12 AM | #6 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Send that video to ECS. They can tell you in a second.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
05-22-2015, 10:23 AM | #7 |
took it apart and the ring was ok, but i didnt look at the washer. the impeller looks to be ok. one of the guys at my body shop looked at the tensioner pulley and noticed it didnt seem right, almost like a bearing was missing. said it sounds like metal to metal rattle from that pulley, almost may be causing wear on the other pulleys. Im not sure what to look for so ill post the pics he took.
05-22-2015, 10:53 AM | #8 |
The surface of my pulleys looks just like that (and I don't have that noise). It could be something internal to a pulley or idler.
05-22-2015, 10:59 AM | #9 |
I figured the pulleys were ok on the surface, i just wanted to double check with others. I do question if its that tensioner pulley though making the sound.
05-22-2015, 12:30 PM | #10 |
Sold car...
Drives: 2010 Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
Hate to be the bearer of bad news. Sounds exactly like mine did and had to be sent back for rebuild.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. |
05-22-2015, 12:45 PM | #11 |
For no charge I hope
05-22-2015, 01:51 PM | #12 |
Sold car...
I wish..it'll probably cost me more than the miles I have on it.
Build Thread
05-22-2015, 01:55 PM | #13 |
That's nuts. What did they determine was the cause
05-22-2015, 02:00 PM | #14 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I have 60k miles on mine and this is always in the back of my mind lol.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
Thread Tools | |
