Old 06-22-2022, 01:46 PM   #15
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Originally Posted by MartinLe View Post
"The more options the better. If you're on the stock blower and long block, you might as well look into E', especially since you've cracked the ECM. That's my vote anyways. Supposing you have E' available...
I have mentioned in other threads about the ease of blending E with whatever you get at the pump. I do not know about CA, but it is easy to buy a 55 gal barrel of E98 here in Oregon (I purchase mine from Tyree Oil and it is delivered to my house.). I read my E content and fuel level percentage off my Banks gauge. I have an ethanol blend app on my phone that is very straight forward. I add the required amount of E and head to the the gas station and tell them to add (yes, we cannot pump our own gas.) x gallons of premium. This has worked well for me. It might be worth a try for you.
That sounds great... if my car was tuned I would have switched to E85 immediately, it's basically held the same price though the inflation spike and it's race gas. Any issues with E98 storage, do you have to use it up fast? Does the 55 gal barrel prevent water absorption / contamination?
Also, how much is a 55 gal drum of E98 per gallon?
Thanks!
SFV1LE is offline   Reply With Quote
Old 06-22-2022, 03:08 PM   #16
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
Thanks!
I go through a barrel in about 5 weeks. I have had no evidence of water absorption. Even in the rainy season, I leave the pump in the barrel and it is not air tight. The last barrel I bought in March (cars been down for mods) was $5.01 per gal.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 06-22-2022, 03:15 PM   #17
SFV1LE
Seems like a fair price and I would be ok paying that, is $5/gal the normal price for E98 due to it being 98%? I think E85 is still under $3.50 here in CA, but it's usually not quite 85%
Old 06-22-2022, 03:24 PM   #18
MartinLe
MartinLe's Avatar
I can only speculate, but I think that you will get a better grade of fuel buying it by the barrel and a more consistent percentage of E content. And remember, it is inexpensive to install an ethanol sensor and our cars love E!
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 06-22-2022, 03:52 PM   #19
ZLRob
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
It is inexpensive to add the flex sensor yes, but it is a pain in the rear to add a boost a pump to the tank short of replacing the low side pump itself. That's really what's stopping me from doing the "conversion."
Old 06-22-2022, 05:22 PM   #20
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
I did the JMS booster myself and it really isn’t that bad. There are a couple of decent “how to” videos that help a lot.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
CW3SF is offline   Reply With Quote
Old 06-22-2022, 05:29 PM   #21
MartinLe
MartinLe's Avatar
There is that, my friend. But really, with all the excellent videos on how to install the JMS - it is easy.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 06-22-2022, 05:54 PM   #22
ZLRob
ZLRob's Avatar
So what, all you need is a pump voltage booster for the low side and not an auxiliary pump like I was thinking you needed?
Old 06-22-2022, 06:10 PM   #23
MartinLe
MartinLe's Avatar
Exactly. Flex fuel sensor, JMS voltage booster, headers, LT5 throttle body, Roto Fab and some plugs. That will make you a whole new monster. And of course, a tune.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 06-22-2022, 06:11 PM   #24
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
The JMS might not be enough for you as you are making 2+ lbs more boost stock. You can probably use the JMS but with lower E concentration.
I told you to just drill The tank
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 06-22-2022, 06:20 PM   #25
MartinLe
MartinLe's Avatar
Sorry, I missed the pulley you are running. But what camaro1973 said is spot on. I had no pulley and was running 60% E. He is already helping you, so it would be easy for him to tune you to the proper E content.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 06-22-2022, 06:40 PM   #26
ZLRob
ZLRob's Avatar
drilling the tank
What I didn't realize is that we can digitally increase low side voltages via HPT. I looked and am set to 15.5 currently, with the highest supposedly being 16.5 before the pump doesn't like the extra voltage and starts dropping off. Think it's worth even doing any of that? I really am not trying to go excessive on E, just enough for it to put it into a level where it doesn't knock anymore without having to get fancy with where I can fill it, or having to rely on octane booster all the time.
It's a 9.06 lower pulley. Mike knows his stuff!
Old 06-22-2022, 06:56 PM   #27
MartinLe
MartinLe's Avatar
drilling the tank
I may have just been coincidence, but I set my JMS to 15.7 volts and shortly there after, my low side pump took a powder??
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 06-22-2022, 07:01 PM   #28
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
drilling the tank
You still need the booster for the actual voltage, not only does it increase the voltage it makes it consistent.
