02-01-2020, 04:37 PM | #1 |
Drives: 2017 Camaro SS Join Date: Nov 2017
anyone every have issues with the serpentine belt tensioner?
This car can be a pain in the ass.
So it seems I messed up the part where you put in the torx-50 bit but it seems good enough that it still should work. It's like it's frozen. Any suggestions? Anyone else run into this? I want to get the car running again. I never had any issue with the LS motors. Thanks |
02-01-2020, 07:55 PM | #2 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I am completely with you there, these new "global" type tensioners and parts on this car are a complete pain. It probably has a lot to do with using global suppliers and unifying GM products to be used everywhere. The radiator setup is a real pita as well.
Anyway, you shouldn't have to mess with the torx bit if you are trying to loosen the belt tension? You should just be able to put a 15mm I think? socket on the idler pulley bolt put a breaker bar on it and turn it down and the tensioner will compress in the down direction. |
02-02-2020, 08:31 AM | #3 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I agree 100% on the radiator. Haven't had any issues with the tensioner though. I've got around 22k miles and have removed & reinstalled the serpentine belt multiple times. Cmitchell is correct on the belt installation technique.
Baby Blue
02-02-2020, 08:33 AM | #4 |
Thanks! Thought about trying that yesterday when I went to bed.
I seem to get stuck on the stupidest things. I guess I couldn't make a living as a mechanic. I am anxious to see how these bolt ons feel. I love the low end power of the stock car but it kind of feels anemic at higher rpms. A little worried about the loudness. Can't complain too much though, these cars are pretty amazing off the show room floor. |
02-02-2020, 06:11 PM | #5 | |
I think a good mechanic is someone who is patient and has a good attention span, someone who stops and gets the right tool instead of messing with something for an hour only to end up breaking it just because you didn't want to crawl out from under the car again. |
