Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 05-30-2017, 05:06 PM   #1
Mkn95u0
Mkn95u0's Avatar
Drives: 2012 IBM L99
Hoosiers D.O.T Drag Radial 2
Hello all,
i've found a few threads with minor information on the Hoosiers, so i figured i'd start one up for informational purposes.
I have 2012 A6 SS Camaro, 645rwhp / 581rwtq
18" x 11" Zl1 style wheels out back
20" x 10" Zl1 style wheels up front
i'm running vredestein Sessanta 275/40r20's up front and running the Hoosier 325/45r18 tires out back
so far, upon my initial tests, my TC lights and everything work as they did before tires. i'm able to turn everything off / back on.
the only thing i noticed is my ABS seems to be triggered / felt through the brake pedal in normal day to day driving. I haven't really tested stopping distance or anything, but figured it may be normal.
I have just under 1.25" between the tire and the outer quarter panel and about 1" between the tire and the inner wheel well worth of clearance.
Any questions, i can try to answer. or any input someone wants to share, feel free to.
some images
Robert
12.012 @ 115.75mph DA: 2371 | 486rwhp/467rwtq (11/8/2015)M
11.265 @ 123.55mph DA: 2318 | 526rwhp/532rwtq (11/19/2016)M
10.722 @ 132.21mph DA: 850 | 645rwhp/581rwtq (12/3/2017)M
10.609 @ 130.19 DA: 975 | 675rwhp/629rwtq (2/16/2020)D
Build: E-Force w/ 3.25" pulley (11lbs of boost), 10% OD under pulley, Fore Dual Fuel System, ID850's, AEM CAI, Borla Long Tubes, Flowmaster Super 10's, Circle D 3200 converter 258mm triple disc lockup, cam 226/242 116+4 LSA, ZL-1 Rear end, E85 & BRC Raceworks Tune (previously known as CMS)
Youtube Channel: http://www.youtube.com/c/RobertMitchellRCM
Mkn95u0 is offline   Reply With Quote
Old 05-30-2017, 10:05 PM   #2
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Total bad ass
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 05-31-2017, 12:42 AM   #3
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
And here I am trying to figure out if 325-18s will fit my setup. Looks awesome!
What else can I do to my Camaro?
ticowarbird is offline   Reply With Quote
Old 05-31-2017, 06:37 AM   #4
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
The Hoosier DR2 hooks on dirt!
BFASTNOTLAST is offline   Reply With Quote
Old 06-01-2017, 09:59 PM   #5
K8811ss
Drives: RS/2SS white/black
Awesome, I'm looking at getting the hoosiers as well. Did you have any trouble fitting the 345s? I was looking at 315s.
UPP 58mm TT, 127lb per hr. Injectors, e85 flex fuel w/ duel Areomotive fuel pumps, TSP stage 3 blower cam 900+hp 9.5psi
K8811ss is offline   Reply With Quote
Old 06-02-2017, 09:04 AM   #6
Mkn95u0
Mkn95u0's Avatar
you just made me realize i put 345's smh. they're 325's. , i feel like an idiot now that i didn't catch that typo
315's will fit no problem. but i wouldn't doubt someone on here has fit 345's with minor bulging on a smaller sidewall
Robert
Old 06-02-2017, 10:42 AM   #7
CGbambam
Drives: 2011 Camaro 2SS
BFH hammer mod you can fit some 345 or with a small spacer
CGbambam is offline   Reply With Quote
Old 06-09-2017, 09:58 PM   #8
K8811ss
I thought 345 seemed a little wide.
Old 06-21-2017, 03:35 PM   #9
DARKTHIRTY777
DARKTHIRTY777's Avatar
Drives: 2011 camaro ss
Thinking about buying these same tires. Any regrets?
2011 ls3 ss/rs, Kooks long tube headers, gutted high flow cats, 231/239. 624" lifted squared 115+3 lsa comp cam, ecs supercharger, Alky methanol kit, DSS 1000hp axles, BMR toe rods, BMR trailering arms, Fore innovations dual fuel pump. Flex fuel sensor and 360 custom tunes, hp tuners NGAUGE. 752 hp with 93 octane and 825 hp with E85.
DARKTHIRTY777 is offline   Reply With Quote
Old 06-22-2017, 12:52 PM   #10
Mkn95u0
Mkn95u0's Avatar
none so far, testing them out at the track first time this sunday. i'll keep the forums posted.
Robert
Old 09-26-2017, 11:35 PM   #11
ZL1-Camaro
Drives: Black M6 2013
So how do you like them at the track?
ZL1-Camaro is offline   Reply With Quote
Old 10-08-2017, 07:03 PM   #12
DARKTHIRTY777
I purchased a set of Hoosier drag radials. I noticed that the rim spun a little bit in the wheel.
Old 10-16-2017, 06:24 PM   #13
GR8WHITE1
GR8WHITE1's Avatar
Drives: camaro
Where did you get the 18" ZL1 replica wheels?
GR8WHITE1 is offline   Reply With Quote
Old 11-21-2017, 02:06 PM   #14
Mkn95u0
Mkn95u0's Avatar
haven't updated this in a while, apologies.
so far i really like the tires, hook better than my old M&H's. i'm still working on getting things dialed in, but so far i've only been able to cut a 1.598 60' (i'm not the best driver btw, just keep that in mind ha - my avg's were around 1.8's-1.9's though now they're 1.6-1.7)
last week marks my 8th run on these tires though, and november was best time of year for us with a low 2500 DA. running them in bakersfield on 12/3 in better weather with some people hopefully can give me some launch tips while there.
overall though, novice to novice runs, they're noticeably better than my M&H's avg 60' time so far.
Robert
