04-20-2023, 09:46 PM | #1 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Mounting a remote mic for GoPro?
I'm using a GoPro on the typical suction cup mount on the small driver's side window. I'd like to get an extension and remote mic to place somewhere around the rear of the car so I get minimal wind noise but good exhaust sound. Anybody have tips on where to mount the mic and how to route the extension cable?
Matt Miller
2020 SS 1LE |
04-20-2023, 10:19 PM | #2 |
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
Good luck, I bought a Purple Panda external mic. and moved it all around my car and still got wind noise. I would pick a spot and then go do a test loop. Then download it and listen to the audio. I put in the glove box with and without the wind sock. Tried it in the passenger foot well. In the truck under the rear speakers. In the very back of the truck. And even in the trunk under the the carpet in the area buy where the tire inflator kit is. Every location had some wind noise with the windows down which is required for most HPDE events. The motor sounds were good. But I never could eliminate the wind noise. I researched this and it seems like the best audio without excessive wind noise is to mount the mic on the outside of the car on the rear bumper. Just don’t cut your mic cord when you close the trunk.
04-21-2023, 07:36 AM | #3 |
I am definitely thinking somewhere outside the car around the rear bumper. A friend of mine mounts one inside the bumper cover on his BRZ, and he gets pretty good results.
Matt Miller
2020 SS 1LE |
04-21-2023, 07:57 AM | #4 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
Anywhere on the back bumper works well for me. I did pinch my mic cable after like 15 trackdays though(had to buy new one) . So maybe look for a way around that. I'm thinking of mounting the entire recorder outside or drilling a small hole from the trunk to behind the bumper.
04-21-2023, 08:21 AM | #5 | |
Shadow Gray '19 ZLE M6
I did some testing with an external mic on various placement spots around the vehicle.
I'm using this mic and a wind sock. For me, given the car is supercharged and I wanted to hear blower sounds, the best spot is in the glove box. This is what it sounds like in the glove box. However, the cleanest exhaust sound I was able to achieve was taped inside the trunk to the hard black plastic panel with some gaffer tape. Anytime I mounted the mic on the rear bumper, the sound was just too loud and would be distorted. As far as routing the cable, I use this extension and tucked it up under the center console along where it meets the carpet and ran it to the glove box. My GoPro is mounted on the roll bar, so I don't have to deal with any wires above the dash area.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
04-21-2023, 08:55 AM | #6 | |
Who Needs to KNOW?
I stick mine near license plate.
I run cable through interior and tape it along body to minimize cable slap. There is windsock/muffler over the mic to minimize wind noise.
ing for grip.
04-21-2023, 01:11 PM | #7 |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
Same, tape it to the license plate frame. I do it every track day.
04-21-2023, 06:23 PM | #8 |
Okay, I have a 15ft extension, adapter, mic, and windsock on the way. I'll experiment with inside the trunk on that back panel and outside on the bumper or license plate. Thanks.
Matt Miller
2020 SS 1LE |
04-21-2023, 07:27 PM | #9 | |
Drives: '94 Z28+ '15 Z/28 Join Date: Jun 2009
Mine is clipped to my rear license plate. Sounds good with zero wind noise.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C 1980 Z28- resto-mod project 1979 Y84 Trans Am 1986 IROC-Z |
04-21-2023, 07:29 PM | #10 |
Drives: 2023 2SS 1LE Join Date: Dec 2022
I was just going to come here to say I clipped mine to license plate frame and it works amazing but I see others have mentioned that. Also helps to have a windsock on it to help with the buffeting.
2023 Riverside Blue Metallic 2SS 1LE Camaro
2021 Black Hyundai Veloster N -Sold- 2016 Grey Chevy Volt -Sold- 2018 Blue AWD Kia Stinger GT2 -Sold- |
04-21-2023, 08:49 PM | #11 |
Who Needs to KNOW?
With long enough cable you can route it down side of windshield for extra supercharger noises
ing for grip.
04-21-2023, 10:23 PM | #12 | ||
04-22-2023, 11:18 AM | #13 |
04-22-2023, 12:27 PM | #14 |
