05-19-2020, 10:28 AM | #1 |
Drives: 2015 Camaro Join Date: Aug 2018
Tach delay for a few seconds after starting the car.
I noticed the other day, when I started my car after a warm restart, the tach delayed for a few seconds. The battery is orìginal, but I always keep it on a trickle charger when I'm not driving it. Car is garaged kept so I assume the grounds are good.
Any ideas? |
05-20-2020, 01:33 AM | #2 |
ttt
05-20-2020, 06:02 AM | #3 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I'd start with a battery
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
05-21-2020, 12:08 PM | #4 |
05-21-2020, 01:57 PM | #5 |
Old batteries in these cars cause all sorts of strange electrical symptoms.
05-21-2020, 02:38 PM | #6 |
Drives: cheby Camaro Join Date: Aug 2019
I'll look when I go today, I think mine does the same thing.
05-21-2020, 04:55 PM | #7 |
05-21-2020, 05:06 PM | #8 |
Is everything else working fine and does it operate normally afterwards? I thought you had some other issues as well but i think i mixed up posts in my head.
05-21-2020, 05:12 PM | #9 |
Yes, everything else works fine. The tach works normally and no other issues. It just freaked me out because I never actually noticed it before. Stays on the battery tender when parked. Original Delco battery.
05-21-2020, 08:21 PM | #10 |
I wouldn't worry about it if that's the only thing you've noticed, could be normal and you just never noticed. If other strange stuff starts happening look at the battery possibility
05-21-2020, 09:25 PM | #11 |
Well I tried it a few times, there is a delay but its not much. If you hadn't mentioned it I wouldn't have noticed.
05-21-2020, 09:57 PM | #12 |
I thought the tach, speedo, and 4 packs did a full test sweep before they started? Or do you mean after that?
05-21-2020, 10:10 PM | #13 |
The speedo and tach don't, as the engine starts the gauges on the console sweep.
05-21-2020, 10:17 PM | #14 |
Wow...I am always missing the details lol.
