04-26-2018, 07:53 PM | #43 |
Black lightning
Old ass post I know. How did the 305s hold up to date just curious on the stock wheel bro? Did you squeeze the 275s up front.
[ 2021 Camaro ZLE 10 speed
04-26-2018, 08:44 PM | #44 |
Drives: 17 SS a8 Join Date: Feb 2010
I have about 2500miles in my 305’s. Best 60’ of 1.60, probably have more in them. Tread is just about gone but they keep working until cords show.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
04-27-2018, 09:13 AM | #45 |
Drives: 2018 Camaro SS 1LE Join Date: Jan 2018
IS your car lowered at all? I'm interested in this tire also but I have a 1LE so I sit lower than you stock. My wheel is wider so I have no problem fitting the tire on the wheel.
04-27-2018, 09:38 AM | #46 |
My ss is stock height. The tires tuck nicely, I think they would fit with a little drop.
10-20-2018, 12:23 PM | #47 |
did you ever figure out the "wag" issue?
2016 NFG 1SS A8
10-20-2018, 01:36 PM | #48 |
over the winter I did all the bmr bars and a cradle lock out kit along with 15" wheels and 325/50/15 dr's and I no longer have the issue. not sure which item or items fixed the problem. I forgot about this issue and am glad to no longer have the problem, it was a little scary.
I can say the car had the sway when 100% stock and it got worse with more power and the 305 dr's.
10-20-2018, 01:41 PM | #49 |
Thanks...I'm still on stock run flats and its stable at all speeds, but it is no longer enough tire for my mods and trans tuning. Trying to figure out which tire to go with. I am probably going to try the Nitto's being I have always preferred them over Mickeys on the street with past rides.
2016 NFG 1SS A8
01-25-2022, 10:30 PM | #50 | |
Drives: 2018 Camaro 2ss Join Date: Jan 2022
01-26-2022, 09:09 AM | #51 |
I have been to the top of 6th gear(A8) with the 305/35/20 555r2 on stock wheel. No wag... super stable...amazing all around tire.
2016 NFG 1SS A8
