11-24-2021, 10:03 PM | #1 |
Drives: Chevrolet Camaro ZL1 1LE: Stage 5 Join Date: Sep 2021
Tire suggestions to get my ZL1 to hook
I have a 2020 ZL1 1LE with a Katech stage 5 build making 861 rwhp and I can blow the tires off at 100 mph. Running Pilot 4s's right now. Need a streetable tire, thinking Forgestar F14 17" wheels so they look somewhat similar to the factory front wheels. Maybe 10.5 or 11" wide. Certainly open to wheel suggestions as well!
Some have said the Nitto 555's are the way to go. Other high power builds have told me they've tried em and they aren't sufficient. Any suggestions please? Need sidewall flex yet still want handling in the corners. |
11-24-2021, 10:42 PM | #2 |
Drives: 2016 Camaro SS Join Date: Oct 2021
I have F14's 19x12 with 325 Toyo R888R's and they hold my 700+whp pretty well.
They are pretty noisy for a daily driver though and you won't get a bunch of miles out of them.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods BTR stage 3 cam - Circle D converter American Racing headers - Borla S-type Last edited by rcoe; 11-24-2021 at 10:44 PM. Reason: add picture |
11-25-2021, 04:42 AM | #3 | |
Thanks! |
11-25-2021, 05:52 AM | #4 |
Just FYI, those suckers grip, but they're loud, I mean monster truck or tractor trailer LOUD at speeds above 45-50 mph. Fine if you don't want to daily drive the car though, I'm sure the roar from your 860 rwhp engine at WOT will overpower them
11-25-2021, 06:22 AM | #5 | |
What are you running Arpad? |
11-25-2021, 06:30 AM | #6 | |
Once these wear out, I'll try Nitto 555R2's in the rear.
11-25-2021, 06:41 AM | #7 | |
Katech Stage 5, Magnuson 2650R, Max effort CAM, Johnson 2110-K Spec Lifters, Trend 3/8-.080 Pushrods, 103mm Katech throttle body and Snout, Billet Valve Covers, Billet Oil Pump, 160 degee Thermostat, 2" ARH long tube headers, catless 3" to stock NPP muffler, Big Gulp, CNC Machined Heads/Head Chambers, Griptec Upper and a bunch of other goodies!
861 RWHP 723 RWTQ |
11-25-2021, 07:09 AM | #8 |
Cold weather is borderline unsafe at big power. If it’s under 60 degrees out I generally will not give it the beans at all as I can literally break the tires loose at any time or any speed. But the scary part is thinking you have traction then having it break loose on an up shift at near or over triple digit speed. It’s just not worth it so I drive like granny until I know weather and traction are both favorable.
11-25-2021, 07:15 AM | #9 | |
861 RWHP 723 RWTQ |
11-25-2021, 07:58 AM | #10 |
I’m with you! The moment snow or salt hits the roads she goes away for the winter. But nothing wrong with sneaking in some nice fall drives until then, even if the temps are a bit cool.
11-25-2021, 09:48 AM | #11 |
Josh is right, as always. Thought this was somewhat obvious, but my rule with these tires is no WOT under 65 degrees in any gear, period (and I have 100-200 less hp than you guys). The car is still plenty fun driven "normally", heh, and come good weather, I let it show some fangs.
11-25-2021, 10:06 AM | #12 |
A 555r2 will help a ton...still not going to be able to dead hook from lower rolls with that kind of power in cooler weather but I wouldn't be surprised if you could roll into from 50 ish and hook. The 17" is a good call with a 305/45/17. You need more sidewall. Imo the 555r2's are the best tire out there that offer the least amount of compromise.
Pros- Quiet, handle relatively well, no rear end wag at high speed, and night/day better traction vs any high performance street tire without giving up much tread life. Cons- Not going to handle like a Super Car tire for high speed cornering but they still handle great for street use.
2016 NFG 1SS A8
11-25-2021, 10:10 AM | #13 | |
Happy Thanksgiving gents. Keep these things on the pavement!
11-25-2021, 10:11 AM | #14 | |
So far sound like Nittos or Toyos are the way to go...
861 RWHP 723 RWTQ |
