12-06-2018, 10:07 PM | #1 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
CA Perf Cat Delete Install Questions
I was actually able to pick up a set of CA Perf cat deletes used a little while back
Question I have is - does anyone know the GM PN# for the gaskets and (2) should I buy a new exhaust clamp for the driver's side pipe? (Not sure if they reuse the stock clamp or you have to cut the stock mid-pipe?)
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
12-06-2018, 10:34 PM | #2 |
Drives: SS 6 speed of course Join Date: Jan 2016
No cutting, I think U use the old clamp. The only gasket was the rings in the down pipe to header, they are reusable.
12-07-2018, 08:22 AM | #3 |
Don't use the old clamp for the slip section...that is why guys complain of leaks.
This is what you want. https://www.jegs.com/i/PYPES/958/HVC...kaAk_KEALw_wcB
2016 NFG 1SS A8
12-07-2018, 03:26 PM | #4 | |
I liked and resused the silver sealant that was on the OEM slip joint. Don't know what that magic stuff was. I did NOT have any leaks. But it has been years since I ran the setup.
