01-15-2019, 11:28 AM | #1 |
Mishimoto Cat-Back and ZZP Throttle Body
I just installed the Mishimoto cat-back w/ quad tips and the zzp throttle body and it sounds like an actual sports car now. I've been getting 12.5 MPG because I can't stop getting on it. I definitely recommend these two products to anyone looking to get a nice deep sound from their 2.0t and to improve throttle response. Also, installation was a breeze.
01-15-2019, 11:49 AM | #2 |
Pat
Drives: 2017 Camaro 1LT I4 Turbo A8 Join Date: Nov 2016
Do you have a catted or catless downpipe?
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro Follow my Build Thread The WhiskeyFed Camaro Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket DYNO SHEET: 297whp / 374wtq Tuned by #danytechtuning |
01-15-2019, 12:29 PM | #3 |
01-15-2019, 12:33 PM | #4 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
Unless you go catless there is no point in replacing the stock for a ZZP Catted Downpipe. Not enough of a real flow difference.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile Last edited by Evil-Bee-NH; 01-15-2019 at 12:43 PM. |
01-15-2019, 12:48 PM | #5 | |
Drives: 2016 M6 2.0T Join Date: Nov 2016
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
01-15-2019, 12:54 PM | #6 |
The videos you posted made me choose this exhaust. Thanks!
HD Cooling and Brakes, Ingen Evo7300, ZZP Throttle Body, and Mishimoto Cat-Back w/ Quad Tips.
01-15-2019, 02:31 PM | #7 | |
Drives: 2018 2SS Join Date: Oct 2017
in back to back dyno testing, (same day, within about 1 hour, without unstrapping the car from the dyno) we found no measurable power difference between the catted, and offroad downpipes (ZZP) downpipes. we did several pulls with both pipes, and it was less than 1 WHP difference between all of them. this was on a bolt on/tune/93 car. both pipes are a noticeable gain over stock. |
01-15-2019, 07:14 PM | #8 |
It sounds even better after it breaks in.
01-15-2019, 07:51 PM | #9 |
Awesome.. just did the same on mine.
01-15-2019, 08:46 PM | #10 | |
603 Camaros
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
01-16-2019, 08:14 AM | #11 | |
i have a flow bench, would you prefer me to put all 3 pipes on that? i can arrange for that to happen if you dont believe that a 400 cell magnaflow cat flows nearly the same as a straight 3" pipe. we did this testing on our ATS in 2014ish, i have no idea where that specific dyno sheet went. its been a 4 years, and that car has changed a LOT. there is probably 500 dyno pulls attached to that car saved on the dyno. just going off memory here. 1) yes, on a stock tune, gains will be MINIMAL with bolt on mods, unless you somehow manipulate the MAF signal. 2) the stock downpipe is not really a restriction at stock boost (power levels) anyways. |
01-16-2019, 11:18 AM | #12 | |
01-17-2019, 03:27 PM | #13 |
Did you buy mishi thru their website or 3rd party?
01-17-2019, 09:39 PM | #14 |
