12-13-2019, 01:55 AM | #1 |
I’m Magik a physco dog
Drives: '15 1LT/RS & '23 3LT/RS Join Date: May 2016
trans shudder question
Does it only effect the V6 ? (i had it on my 2016) i'm looking at a 2.0 turbo motor 2016 MY.
TIA, Rob.
2023 3LT RS Shadow Gray
2015 1LT R/S Blue Velvet Coupe. Previous: 2015 1LT Ashen Grey 2016 1LT Blue Velvet My entire life has been 'A Midlife Crisis' |
12-13-2019, 04:08 AM | #2 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
Anything with the 8L90 or 8L45
12-13-2019, 09:06 AM | #3 |
2016 NFG 1SS A8
12-13-2019, 09:16 AM | #4 |
Nope. Doesn’t matter what engine you have, if you have the 8L45/8L90 transmission, you WILL experience the shudder.
12-13-2019, 10:03 AM | #5 |
ok, thanks guys for the reply's.
12-14-2019, 10:15 PM | #6 | |
Drives: 2016 2SS Convertible Join Date: Dec 2019
Didn’t pay much attention to what we already had, and hadn’t heard of the 8L issue until getting on this forum, but Wife has a 16 CTS with the 8L behind a 2.0T, 30k some miles, and it’s never done it. [My DD is a 17 XT5 also with an 8L behind a 3.6, nearing 30k, and it’s never done it.]* Keeping my fingers crossed for the Camaro, but it still has 2 years on the Powertrain warranty so if it comes up I’ll get the fix. *Edit: scratch this, it’s not an 8L. It’s an 8 speed but it’s transverse. Different tranny completely! My bad.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes Last edited by TP2SS; 12-15-2019 at 09:29 AM. |
12-14-2019, 10:28 PM | #7 |
I'd get the latest fluid and flush done regardless of the shudder or not. Good preventative maintenance IMO.
12-14-2019, 10:36 PM | #8 | |
It only has 1900 miles on it and new TSB says no diagnostics required so I’m gonna insist on it being done as preventative, before trans gets damaged with older fluid. Luckily there’s half a dozen dealers within 20-30 miles of me, so if one gives me a runaround I’ll just go to another.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
12-14-2019, 10:45 PM | #9 | |
12-14-2019, 10:48 PM | #10 | |
Since then, the car has driven a hella lot smoother. If anything, the trans is shifting better and is a little more responsive. Only time will tell if this new fluid is truly the cure or is just a bandaid fix. My car is in storage as we speak, I’m definitely ready to drive it again! |
01-24-2020, 05:55 PM | #11 |
Drives: 2024 Radiant Red 2SS, 1994 Z28, Join Date: Jan 2013
My dealer pulled the can not duplicate it and then offered to do it for only $550. I refused but had them put it on my receipt. I also have an extended GM warranty and hope it will be covered under that one since I know have 64000 miles and can replicate it on command.
