Old 10-16-2018, 05:39 PM   #1
2SSAustin
Drives: 1LE 2SS Camaro
Wheel Hop
Was leaving for work this morning turning onto the highway and I got to 30kmh and put the pedal down and what I think I was feeling was wheel hop let off instantly.
No TCS cut in cause I had it turned off, Might it be the Electronic Diff?
If anyone else experienced this what did you do to eliminate it?
Absolutely no mods done to the car yet 2018 2SS 1LE.
2SSAustin is offline   Reply With Quote
Old 10-17-2018, 08:17 AM   #2
Laststandard
Drives: 2018 1SS 1LE
Why would you turn off TCS if you're driving it on the street?
2018 1SS 1LE (sold)
Laststandard is offline   Reply With Quote
Old 10-17-2018, 08:20 AM   #3
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
i usually have TCS completely off when driving PERIOD @Laststandard, but OP, I have found that BMR is very helpful in this matter and i will be purchasing there suspension parts to help resolve our bad wheel hop on these cars, its at around $800 for the parts needed. I'll get the info to you but i just have to go searching for the info. I'll be purchasing these early december as thats when i get back from being out of the country and my build will begin. So i'll definitely update once those are in the car as when i'm at the track its 10x worse then when i'm on the street.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 10-17-2018, 08:40 AM   #4
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
mine had wheel hop. Got the alignment checked and the rear toe was way off. Wheel hop stopped. If that doesn't help you need to go further with the BMR lockout kit or solid cradle bushings.
Pollock is offline   Reply With Quote
Old 10-17-2018, 09:37 AM   #5
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Originally Posted by Pollock View Post
mine had wheel hop. Got the alignment checked and the rear toe was way off. Wheel hop stopped. ...
I've never had wheel hop, and also I had mine set to the GM Track alignment as part of the PDI. Anecdotal, but not necessarily irrelevant. It's exceptionally rare for a Camaro to come off the shipping truck with a good alignment.
Old 10-17-2018, 09:47 AM   #6
2SSAustin
Cause I like to party
Also so I dont have power cut if I start spinning, Pedal the car
Old 10-17-2018, 09:50 AM   #7
2SSAustin
Awesome thank you ill start looking into them aswell. That was a very ugly feeling and dont imagine Warranty covers that lmao.
Old 10-17-2018, 10:13 AM   #8
Pollock
LT4 M6
Pollock's Avatar
You dont have to tell them the whole story.
Old 10-23-2018, 02:19 PM   #9
SaphfireSS
Drives: 2017 Camaro 1LE SS
Wheel hop in 6gen Camaros depend mostly on road surface. You should t see much in a 1LE but it does raise its weary head sometimes. And yes bmr’s mods for wheel hop will help matters. Remeber this car was designed for road course and you should never have wheel hop on track.
SaphfireSS is offline   Reply With Quote
