05-20-2018, 12:02 AM | #1 |
Train Driver
Drives: 2018 Summit White ZL1 1LE Join Date: Jun 2013
Exhaust tip height concerns..
I just installed the Hooker crush pipe eliminator kit. Everything fit great I thought. When I pulled the car off the ramps, I looked at the exhaust tips and they seemed lower than before. The brackets are all flat, and everything looks good underneath from what I can see. I took some pictures of them to see if someone can compare to there's. Thanks for looking. Let me know what you think about the exhaust tips. Are they too low ??
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / / |
05-20-2018, 12:52 AM | #2 |
Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
Did you notice any difference in sound?
05-20-2018, 03:39 AM | #3 |
Drives: 2018 ZL1 A10, 2019 BMW X5 Join Date: Dec 2016
Definitely lower than they should be. Mine don't really extend past the bottom of the bumper/diffuser.
2018 Nightfall Gray Metallic Camaro ZL1 - A10
Purchased 9/23/2017 |
05-20-2018, 07:23 AM | #4 |
Train Driver
No sound difference that I can tell from startup. I've not driven it yet. Look at the hanger on the muffler on yours,it's a 1/4" rod. That is the best way to tell the height if the muffler. You can see mine is visible. Is yours?
2018 Camaro ZL1LE
05-20-2018, 07:48 AM | #5 |
Drives: 16 ngm ss Join Date: Jan 2017
Looks too low to me. I would try to adjust the slip fit and see what effect that has on the tip height and angle.
05-20-2018, 07:51 AM | #6 |
Train Driver
It looks low to me. But can't figure out what is off. Can someone take a picture straight on like did so I can see far it's off.
2018 Camaro ZL1LE
05-20-2018, 09:45 AM | #7 |
Drives: 2018 Garnett Red ZL1 Join Date: Mar 2018
Best I could do for you on a Sunday morning |
05-20-2018, 11:44 AM | #8 |
Thank you Al Oppenheiser!
Red Dragon, based on the height relative to the muffler support I'd say you're about 1/4" low.
05-20-2018, 12:38 PM | #9 |
Train Driver
Ithink you are about right. I stopped by the local Chevy dealer and snapped some pictures of a new ZL1. The exhaust hanger on the muffler is a 1/4" or 3/8" rod pointing out towards the rear bumper. The bottom on that rod is even with the top of the cut out in the tailpipe opening. Mine is visible as you can see from my original post. So. Now I have to figure out how to lift it up. The new pipes must be forcing it down some. I cut them very close on the length,so they are bottomed out in the slip fits. I may have to pull it all back off and cut off 1/4 " in length off each ends of the stock pipes where I cut them the first time. Grrrrrrr...
2018 Camaro ZL1LE
05-20-2018, 01:20 PM | #10 |
Drives: Grandad's C2 L89 Join Date: May 2017
+1
2018 ZL1 1LE sw/PDR
05-20-2018, 02:11 PM | #11 |
Train Driver
You guys are awesome. Thanks so much for the help and pictures. I'll have to see what I can adjust.
2018 Camaro ZL1LE
05-22-2018, 07:03 PM | #12 |
Train Driver
After adjustment. Think it's good as it was before. Car sounds different, a little, but hard to tell. Glad to get rid of those pipes. I am going to Dyno soon with Katech TB, AEM drop in, and no more crushed pipes. See what she will do...
2018 Camaro ZL1LE
05-22-2018, 09:52 PM | #13 |
Not to be a negative Nelly but there's no way deleting the ~8" of crushed pipe by the axle of this car is going to do anything sound or HP wise, unless you're pushing big power, then everything starts to come into play. If you scrapped the secondary cats THEN you would notice a different. I don't see why you'd cut up the stock cat-back just to delete that, shoulda just went with a Borla 60606 or 60607 at that point. That would delete the crushed, and delete the secondary's if you want (60606 does, 60607 doesn't).
05-22-2018, 10:26 PM | #14 | |
Train Driver
2018 Camaro ZL1LE
