09-11-2018, 01:59 PM | #1 |
Drives: 2017 2 SS vert Join Date: Jul 2018
Water laying in trunk weatherstrip area
I am new. To Gen 6 Camaros
Mine is a convertable, and when I wash it soap and water puddles in the sides of the top of the fenders where the weatherstrip goes when the trunk lid closes I see this when I open the trunk and it goes to the plastic fillers above the lights I can see an issue with rust with no where for the water to go There is what looks like a filled hole or a spot weld in the bottom where the water sits Is this normal? |
09-11-2018, 03:14 PM | #2 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
My Vert does the same thing, I always dry the "JAMS" and wax them too!!!!!!
09-11-2018, 03:34 PM | #3 |
Drives: 2017 V6 RS Covertible Join Date: Mar 2018
09-11-2018, 03:45 PM | #4 |
09-11-2018, 03:46 PM | #5 |
Drives: 2000 GMPPSV SS & 2017 ILE SS Join Date: Jul 2017
I dry all my jambs after every wash... after I blow out all the stray water with an air hose.
09-11-2018, 04:08 PM | #6 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Good hydrodynamics are a big part of modern automotive engineering, however they're of course designed to a budget, project time-frame, and expected product life. It's a car, and the current benchmark design life is 150k miles. Expect it to rust after that unless you put in the labor to ensure water doesn't remain trapped, just like the lesson you learned with your GTO.
09-11-2018, 06:17 PM | #7 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
This is where the water drains at. I blow mine out so moisture doesn't sit there but it's designed that way.
09-11-2018, 06:19 PM | #8 |
Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28 Join Date: Jun 2018
Every car ever built has places where water collects. Part of normal care is drying these areas. For the greatest success in drying them, invest in a Metro Master Blaster.
09-11-2018, 06:27 PM | #9 |
Thank you Al Oppenheiser!
The last part of my wash/dry routine is to open the trunk and dry the underside of the lid, drip tray, lights and let the wing stanchions drain. Then I partly open the top to get under the tonneau to the wheel wells, bottom side of tonneau, and all the rubber seals around the top.
09-11-2018, 08:10 PM | #10 | |
I always blow my car after I wash it and dry again |
09-11-2018, 08:51 PM | #11 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
You probably don't want to that water gets into your door when you wash your car or it rains. That's why there are drain holes in the bottom of your door and a water barrier sealing the door opening required to assemble the door. Anyone blowing that out
