09-06-2018, 10:57 PM | #1 |
Drives: 2016 Camaro SS Join Date: Aug 2016
2016 Camaro passenger door wont physically open.
My passenger door will not open from the outside nor through the inside. The car was wrapped and it was dissasembled BUT I am 100% sure everything was put together the exact same way as OEM. The door was opened multiple times prior to this issue. All that happened was, I closed it, locked it, and attempted to open it again but it wouldn't budge. All electronics including the key work. My guess is the door latch is just stuck. Does anyone have a diagram of the door mechanism? or does anyone have any idea how to remove the door panel with the door closed? Any help or advice aside from taking it to the dealer is much appreciated.
09-07-2018, 06:28 AM | #2 | |
Drives: 2018 SS Join Date: Jun 2018
Maybe this helps?
09-07-2018, 07:34 AM | #3 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
When you press the lock/un-lock button on the door or the key fob can you hear anything inside the door?
It sounds like the door is locked and the electrical isn't working. Pretty tough to jam up a door latch unless you really try hard to hood up the rods and cables incorrectly...………..easier mistake is to just not hook them up at all. But I'm not sure what you mean by "it was wrapped and disassembled". Why would you remove door trim and do anything with a door latch to wrap the car? If it's locked and you aren't hearing the actuator you'll have to pull the door trim as suggested above. But that's hard to do with the door closed. You may need to find a competent thief to break in for you.
09-07-2018, 07:50 AM | #4 | |
Drives: Love the one you're with Join Date: Sep 2009
I can't image trying to remove the door trim with the door closed. |
09-08-2018, 01:13 AM | #5 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Well if it workrd before, then it was NOT put back 100% correct. Could be a connector....
2012 Yukon XL Denali w/ 6.2 AWD |
09-08-2018, 09:29 AM | #6 |
Haven’t seen the inside of a door for a few years but it could also be a linkage clip too!
09-08-2018, 09:15 PM | #7 | |
09-08-2018, 10:16 PM | #8 |
Drives: 2SS Hyper Blue Join Date: Jun 2018
Have you tries having someone climb in the pax side and put a good shoulder into the door when you lift the latch with your break in tool.
2018 Hyper Blue 2SS - SOLD
09-09-2018, 10:31 AM | #9 |
I wonder if a piece of vinyl wrap could have somehow wedged the striker in the latch.
09-11-2018, 09:38 PM | #10 |
Tried that today and nothing. Managed to open the door panel just enough to see see the actuator. I can see it lock and unlock but the door will not open. Im assuming the actuator just broke on the inside somehow. I am now hoping my warranty covers it because I cant think of anything else. Just wondering now if anyone else has had this issue?
09-14-2018, 09:33 AM | #11 | |
Passenger door won’t open
09-14-2018, 10:32 AM | #12 |
I had this happen on an old Honda and it was a nightmare.
The basic procedure: 1) remove interior door panel with door closed. This sucks. 2) you need knowledge of the layout of the actuator. Drill a hole in the actuator so you can manually advance the gears which drive the unlatch mechanism. You drill the hole so you can get a screwdriver in there to move the gears. On a seized mechanism the gears could be very stubborn. This part actually sucked worse than removing the door panel! 3) this should get the door open, then you rebuild. This was easily one of the most frustrating car repairs I have done in the last 30 years! |
09-14-2018, 04:33 PM | #13 |
Drives: 1968 SS/RS, 2006 H2 2016 2SS White Join Date: Sep 2015
Weld the other door shut, paint orange and add a confederate flag to the roof. Problem solved.
2016 2SS White fully loaded
09-14-2018, 06:57 PM | #14 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
